Old 08-17-2012, 07:48 AM   #1 (permalink)
Scandinavian creature
Golf ball - '94 Volkswagen Golf III
90 day: 28.46 mpg (US)
Throttle plate delete?
Hellou.
About the throttle plate, the butterfly valve...
I've found some mixed info about this, that it would increase FE or something.
It controls the airflow going in. but does it control the fuel/air ratio? Or if i delete it, then the ECU has no option but to lower the fuel flow, therefor slowing the car down?
And i'm talking about petrol engine
So what are your thoughts about this?
EDIT: I read a little more, and found out that if it's deleted, the idle would be enormous
But, if i play with the TPS signal, i could adjust the air/fuel ratio?
Brrrmm
Now selling preassembled MPGuino's!
http://www.mthtek.net/mpguino/
Old 08-17-2012, 09:21 AM   #2 (permalink)
It is not possible with a gasoline engine. Gas engines are throttled with the throttle body and air/fuel ratio is kept via other sensors. Diesel engines are throttled with how much fuel is injected and air/fuel ratios are all over the map.
Old 08-17-2012, 11:08 AM   #3 (permalink)
a gas or petrol engine wants 14:1 mixture or so, or it will not fire at all.
if you add a bunch of air, you have to add fuel. add fuel and air, and it idles very very high.
I have thought about firing the injectors only once in a while to limit RPM.
Old 08-17-2012, 11:13 AM   #4 (permalink)
Volt, gas only - '12 Chevrolet Volt Premium
90 day: 38.02 mpg (US)
Volt, electric only - '12 Chevrolet Volt Premium
90 day: 132.26 mpg (US)
Yukon Denali Hybrid - '12 GMC Yukon Denali Hybrid
90 day: 21.48 mpg (US)
Not possible. If you're interested in engine mods you should start with the air delivery and exhaust, then combustion chamber, port matching.... Roller bearings if you really want to throw time and money around.
Old 08-17-2012, 12:07 PM   #5 (permalink)
Yea, i was just thinking in theory
I'm about to make the CAI, when i got time. I already made a hole in the airbox, but got no time for more 50% done.
But since my car has no air mass meter or any fancy things, only cold/warm switch on airbox, and air temperature meter at the throttle body, should it be possible to adjust the air/fuel ratio by adjusting throttle position sensor?
Im my car, i would need to adjust it for 33% for it to be 14,7:1.
Or something i'm not noticing here?
Brrrmm
Old 08-17-2012, 01:54 PM   #6 (permalink)
darcane's Avatar
It *IS* possible to run gasoline engines without a throttle plate! BMW does it:
Valvetronic - Wikipedia, the free encyclopedia
Fiat and Nissan also have versions of this.
But it's really not feasible to convert a conventional throttle engine to a valve-throttled engine.
Past Cars:
2001 Civic HX Mods
CTS-V
2003 Silverado Mods
Old 08-17-2012, 02:21 PM   #7 (permalink)
Hypermiler
PaleMelanesian's Avatar
90 day: 69.2 mpg (US)
PaleFit - '09 Honda Fit Sport
Wagons
90 day: 44.06 mpg (US)
Honda's R18 engine in the Civic has a modified valve timing mode that allows a more open throttle for low power cruise. It keeps the intake valve open longer so some of the air is pushed back out before the compression stroke.
Old 08-17-2012, 02:58 PM   #8 (permalink)
You are talking about eliminating the gasoline engines isobaric intake expansion (throtteling).
The easyest way to do that is relocate your otto engine to the junk yard and put a turbodiesel in its place.
That would replace your isobaric expansion with double isentropic compression (through the turbo charger compressor and maybe a little isobaric heat rejection through the intercooler, then into the cylinder for compression).
On a gas engine you play a limited game mostly around the throttle plate.
On a turbodiesel the concept is simple: stuff more air into the engine all the time, get better milage and more power.
Old 08-17-2012, 04:40 PM   #9 (permalink)
vskid3's Avatar
Civic DX (sold) - '97 Honda Civic DX
90 day: 34.15 mpg (US)
GTO (sold) - '04 Pontiac GTO
90 day: 22.62 mpg (US)
Green Brick (sold) - '06 Ford Escape Hybrid
90 day: 31.93 mpg (US)
http://ecomodder.com/forum/showthrea...less-9092.html
This has been tried before, ended up melting a piston because he went too lean.
Camry Thread
E-Bike Thread
