Originally Posted by Cobb
You can cut springs, oem and lowered ones. Thats ow the pros get that nice lowered look with plus size wheels and tires. In those cases for something that low you need to cut or even remove the bump stops. My tanabe springs set for my insight said to cut all but an inch off the bump stops.
Sometimes lower springs sag. My sidekick has tires 3x larger than oem and hr lowering springs. The rear is saggins and I have to add an inch spacer in the rear to level it out and stop the fenders from hitting the tires on bumps.
Since it looks like you are more interest in performance than mpg, maybe try a forum for your car?
It is not a good idea to cut springs due to the fact that most have Vehicles that use progressive spring rates,
I own the same chassis as the OP, which is why I chimed in on my setup.
The "Pros" don't use cut springs and level spacers, they run coilovers. Lowering isn't just for appearance it's for the sport
IE handling, wheel fitment and aerodynamics.
Of course one would have to shorten the bumpstops if you run a shorter spring and strut/shock, but most strut/shocks are not made to bottom out and will break.
There is nothing wrong with leveling spacers other than they shorten your strut/shocks stroke length. I have one inch spacers on my vw on the rear since I like to carry all of my luggage and tools, as well as a full tank.
Sounds like you need to roll/modify your fenders or have taller bumpstops.
I am assuming this was towards me,
if I was interested in performance, I would have not bought a vw nor would have joined ecomodder.com
