Old 11-05-2018, 03:20 PM   #1 (permalink)
Camry - '03 Toyota Camry LE
Question 2003 Camry 4 Cylinder 2.4l
My Camry has 241k miles on it and without trying to hypermile I can easily get 30 mpg on the highway. I drive mostly highway and some back roads. With hypermiling driving techniques what do you think I could get my MPG to? I would like to see 35. Do you think it's possible? Thanks!
The Following User Says Thank You to Zebulon1993 For This Useful Post:
TDFbound (11-25-2018)
Old 11-05-2018, 03:23 PM   #2 (permalink)
mpg_numbers_guy's Avatar
Toby - '13 Toyota Prius C
90 day: 63.99 mpg (US)
Daz - '15 Mazda 3 iTouring w/ Tech Package
Team Mazda
90 day: 38.2 mpg (US)
I got 32-33 MPG driving an '04 Toyota Sienna minivan on the highway. 40 MPG highway with the Camry should be fairly easy with hypermiling techniques. I think there's a thread on here where MetroMPG tested out a Camry of the same generation and it's results were surprisingly good for such a large car.
2013 Toyota Prius C 2 (my car)
2015 Mazda 3 iTouring Hatchback w/ Tech Package (wife's car)
The Following User Says Thank You to mpg_numbers_guy For This Useful Post:
Old 11-05-2018, 03:27 PM   #3 (permalink)
What do you think is obtainable by just hypermiling through the way I drive and that's it? (As in no wheel covers grill covers etc.)
Old 11-05-2018, 03:39 PM   #4 (permalink)
Team Mazda
The key to hypermiling is to slow down and conserve momentum - but by doing it safely. Check out the 100+ Hypermiling Tips page for some examples.
Also, air up your tires to sidewall max. That should be good for a couple MPG and takes no time at all.
Old 11-05-2018, 03:50 PM   #5 (permalink)
Won't that make my tires wear out faster?
Old 11-05-2018, 04:15 PM   #6 (permalink)
90 day: 29.78 mpg (US)
Increasing air pressure won't make the tires wear more quickly, and might even make them last slightly longer, assuming you aren't accelerating or braking too quickly. Overinflated tires don't have to flex as much, meaning they don't generate as much heat, meaning they should last a bit longer with the possible downsides being increased road noise, harsher ride, and possibly worse handling characteristics.
You could probably get 50 MPG if you drove at 45 MPH.
Old 11-05-2018, 04:50 PM   #7 (permalink)
Oh ok. I've always heard it'll make the center wear out faster on the tires.
Old 11-05-2018, 06:48 PM   #8 (permalink)
I've not ever experienced that. The side of my tread always wears out first but I take corners much faster than most people because a. it's more fun and b. preserves momentum. I'd wager that most on here do not have an issue of wearing out the center of their tires. It may have been an issue with old style bias ply tires.
PM Capriracer if you want to know everything about tire pressure, wear, performance, etc, etc.
Old 11-12-2018, 08:14 AM   #9 (permalink)
90 day: 39.72 mpg (US)
90 day: 59.69 mpg (US)
With an automatic Camry, you're pretty much limited to slowing down on the highway, if you're not interested in any modifications to the car itself. This is assuming you're not riding people's bumpers and frequently using your brakes during steady-state driving - brakes basically convert gasoline into brake dust and heat.
Old 11-14-2018, 01:07 PM   #10 (permalink)
Master Novice
elhigh's Avatar
Josie - '87 Toyota Pickup
90 day: 29.5 mpg (US)
90 day: 49.47 mpg (US)
Redpoint already said it, and I'm just adding: I don't think so. I haven't experienced accelerated tire wear, and I'm running my Prius at 50psi. My truck gets 45psi. Wear hasn't changed for me.
Slow down. Going twice as fast requires eight times as much power, so backing off even a little makes a big difference to how much power it takes. Averaging 60mph takes only 78% as much engine power as averaging 65mph, while being only 8% slower. Leave a couple of minutes earlier, back off the gas a tiny bit, and the savings can be significant.
You could experiment with some stealthy grille blocks, behind the grille of your car. Block off those regions that don't actually open directly onto the radiator. They won't show from the front, especially if you take a few minutes to paint them black once you get the locations and sizes adjusted to suit you. NOTE: monitor engine operating temperature carefully when you do this.
The Following User Says Thank You to elhigh For This Useful Post:
