Old 06-18-2008, 10:26 PM   #31 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
the mpguino NEEDS to be connected to the 12 volt battery so if there are any vss pulses or injector pulses it will still count them. If you EOC without an ignition kill switch then you might not get readings while the key is off, but only because the car stopped sending them. The readings should return when the key is turned back on.
Old 06-18-2008, 11:23 PM   #32 (permalink)
MP$
diesel_john's Avatar
Send a message via MSN to diesel_john
Smile
My VSS gives a signal whenever turning with or without a car hooked to it.
My KEL injector based computer switches to gal per hr if it sees no VSS signal.
Problem is during EOC it turns off because the injection signal is what turns it on and keeps it on. Instead of sensing either signal. ithink, i better double check that.
Old 06-18-2008, 11:33 PM   #33 (permalink)
dcb
needs more cowbell
dcb's Avatar
Switching to GPH is an interesting idea...
Technically we typically tap into an ECU speed signal, my saturn has a hall sensor vss, but the ECU converts it to a 12 volt signal. The metro has a switch in the speedo.
Old 06-21-2008, 09:26 PM   #34 (permalink)
dcb
needs more cowbell
dcb's Avatar
I was thinking about if/what to do if vss pulses is 0 and injector isn't on the guino. A big part of me wants to set off a 200 decibel alarm if that situation persists for more than 10 seconds
Old 06-30-2008, 06:55 PM   #35 (permalink)
Iwishthiswasamanual - '98 Ford Escort ZX2
90 day: 32.95 mpg (US)
Trying to keep main thread clean again...
Plan on ordering parts tomorrow...
What information on pulse rates or something do i need to find out? and how can i find them out?
Old 06-30-2008, 07:10 PM   #36 (permalink)
dcb
needs more cowbell
dcb's Avatar
I updated post 1 under the installation notes for some online sources of vss info. on rostra it lists your zx2 as 8000 (probably really 8208) pulses per mile and gives some details how to find it on the ecu plug.
Old 07-01-2008, 07:33 AM   #37 (permalink)
Baz - '93 Peugeot 106
90 day: 62.39 mpg (US)
Has anyone else used one on an older European diesel yet?
Goal: 3L/100KM
Old 07-01-2008, 07:38 AM   #38 (permalink)
dcb
needs more cowbell
dcb's Avatar
I haven't heard of any. It will take a little extra sensor hardware. Diesel John has had some luck with an old flow meter: http://ecomodder.com/forum/showthrea...html#post10747
MPGuino release one workspace dcb OpenGauge / MPGuino FE computer 1061 01-17-2020 01:37 AM
Gas scooter questions raddevon Motorcycles / Scooters 12 06-06-2011 09:34 AM
wheel airdam - deflector - strake? design questions lunarhighway Aerodynamics 14 04-02-2009 12:45 PM
Misc pumping losses questions tasdrouille General Efficiency Discussion 11 03-27-2008 08:14 PM
