Old 03-23-2012, 02:24 PM   #1 (permalink)
Buggie - '01 Vw Beetle TDI Gls
Diesel substitute?
I know you can cook up bio diesel and veggie oil, all good stuff, but what else will diesel engines run on? Tractor hydraulic oil, engine oil, transmission fluid, powersteering fluid; I think these will work but the engine may no be happy in the long term
Ideas?
Old 03-23-2012, 04:38 PM   #2 (permalink)
UFO
UFO's Avatar
Colorado - '17 Chevrolet Colorado 4x4 LT
90 day: 23.07 mpg (US)
All sorts of toxic soup.
Best one I've heard is transformer oil from old power transformers, mineral oil with PCBs. And used engine oil, all sorts of particulate matter and metals will spew from the exhaust.
Most modern diesels will have trouble with anything other than diesel fuel, but my '82 Mercedes would run on anything, including oil-based paint. Perfect for the zombie apocalypse after the EMP destroys all the computers and digital infrastructure.
I'm not coasting, I'm shifting slowly.
Old 03-23-2012, 09:07 PM   #3 (permalink)
Diesel_Dave's Avatar
White Whale - '07 Dodge Ram 2500 ST Quad Cab 2wd, short bed
90 day: 37.68 mpg (US)
Originally Posted by bandit86 View Post
....but what else will diesel engines run on?
Define "run".
Diesel Dave
My version of energy storage is called "momentum".
My version of regenerative braking is called "bump starting".
1 Year Avg (Every Mile Traveled) = 47.8 mpg
BEST TANK: 2,009.6 mi on 35 gal (57.42 mpg): http://ecomodder.com/forum/showthrea...5-a-26259.html
Old 03-23-2012, 11:31 PM   #4 (permalink)
90 day: 19.36 mpg (US)
Originally Posted by diesel_dave View Post
define "run".
lol!
Old 03-24-2012, 12:42 AM   #5 (permalink)
90 day: 29.78 mpg (US)
I dump used motor oil from a car change directly into the fuel tank. I figure it's been filtered thousands of times, and then once more through a 10 micron fuel filter before it gets to my injectors. Of course, this is just 1 gallon of oil in a 35 gallon tank, and it's twice per year.
I've heard not to use power steering fluid, but I don't know why. I've also heard transmission fluid works, but will loosen up any crud in your fuel system and plug your fuel filter in a hurry.
I'd probably run any of these mixed with diesel in my truck. Anyone know how tiny I should be filtering to?
Old 03-24-2012, 07:41 AM   #6 (permalink)
JasonG's Avatar
05 DMax - '05 Chevrolet 2500HD
90 day: 18.48 mpg (US)
Its very dependent on the engine.
Use a 5 micron filter, 10 at worst.
I back burn my motor oil at 10:1 in the 6.5 but would never in a VW TDI
The old mercs would run on nearly anything.
Somebody (here?) Worked at a shop and would mix barrels of used oil with tranny fluid to get a decent viscosity and burned that for years.
What engine are you contemplating ?
Does it use single hole or multi hole injectors ?
Biggest question is what pump is on it ?
I can't understand why my MPG's are so low..........
21,000lb, 41' Toy Haulers are rough on FE!
Old 03-24-2012, 04:15 PM   #7 (permalink)
If the junkyard is full of dirt-cheap ultra low mile engines . . and a top mechanic owed me a lifetime of low-cost, highest quality work . . then maybe.
I recommend pricing a new factory replacement engine. And a factory re-manufactured engine. And FSM hours for replacement. Add 10% to all.
Then figure how much you'll "save" by running dirt and metal through the motor you currently have.
Break even on my truck should be close to $20k. I might need to drive 300k to recoup my potential loss.
So long as one is comfortable with that kind of equation then have at it.
Old 03-24-2012, 09:03 PM   #8 (permalink)
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
Ideas?
certain Ford diesels will run for a very long time on M85 if it is
1. Filtered
2. Cetrifuged
3. Engine is tuned for M85
Generally speaking, non-TDI diesels can physically run on WMO or WVO blends but it is only economically feasible if you
1. Have lots of free time
2. have unlimited free injectors and injector pumps.
I have noted a couple folks who would tear out injectors every few weeks on their old 6.2s, replace with a clean pair and clean out the engine and button up in about 4 hours.
The parts they had to use were free or reusable and it was only their time and tools.
A better approach in my oppinion is
How to turn plastic waste into diesel fuel cheaply - Page 5
which works on motor oil as well.
Why break your engine when you can make fuel that is closer to what belongs in the diesel to begin with?
Another alternative is to run CNG into the intake under specific load conditions, you can save about 50% of the diesel and use 50% CNG which is much less expensive than diesel.
Good Luck
Ryan
Old 03-25-2012, 01:18 AM   #9 (permalink)
Phantom's Avatar
Blue Meanie - '02 Volkswagon Golf TDI
90 day: 48.52 mpg (US)
Wife's car - '05 WV Passat TDI
Rudy - '94 Chevy C2500
If you run anything other than diesel you should always run clean diesel for the last min or so to clean the injectors some and prevent them from clogging as easily.
I move at the speed of awesome.
"It's not rocket surgery!" -MetroMPG
Old 03-25-2012, 06:05 AM   #10 (permalink)
Heated vegetable oil in a VAG diesel
I've read reports of good results using a two tank system, and a heated fuel filter with clean vegetable oil... (Warm up the engine using diesel and switch back to diesel to purge the pump of the thicker oil before stopping)
Here in the UK you can use up to 2500 litres of veg oil annually without paying, or even registering for payment of duty. So I could potentially make a 30% saving each time I fill up - at the price I would pay for veg oil in a local supermarket!! Buying it wholesale could increase the savings a lot more!
I'm seriously thinking of trying it out...
