Old 04-15-2014, 06:30 PM   #11 (permalink)
hypermiller somewhat.....
Sierra - '13 GMC 1500 SLE
90 day: 12.24 mpg (US)
Cruze Eco - '15 chevrolet Cruze Eco
Team Chevy
90 day: 46.52 mpg (US)
Originally Posted by ConnClark View Post
Just an observation in this discussion.....
I would suspect your fan controller is using pulse width modulation i.e. All the way on and all the way off. Otherwise it would be very inefficient electrically and hard on the electric motor. Your volt meter probably can't react quickly enough to the pulses so its showing a rough average.
However the volt meter can still be used to show a change in power delivered to the fan motor
it is a solidstate invertor of some sort, I did happen to look inside. If I get too curious I might poke around with a scope. It does have about 5 square inches by 1/4 inch high heatsink.and about 100 components. lol
I guess the folks at Denso did find an efficient way to modulate the fan speed.
The trip home has finally given my the last little bit of data.
Approximately 101 and if it lingers at the temperature long enough it will finally go to 13.00 volts which is about 0.3 less than monitored battery voltage. and it will stay at that voltage intil it drops down to 99 degree C
I now know where toyota wants the temperature to be regulated at.
Now I must get back to some ideas for the grille block / air scoop.
Old 04-15-2014, 07:35 PM   #12 (permalink)
Drive less save more
ecomodded's Avatar
90 day: 60.42 mpg (US)
After checking your gas log I noticed you do burn threw a tank of gas before filling, good one. Also seen you put on about 4000km a month which is one hellva test mileage for testing improvements and really helps to get an average which is what counts.
Save gas
Old 04-15-2014, 08:21 PM   #13 (permalink)
Team Chevy
Every last drop if i could. I start to get beyond brave at 60 km past the warning light. There is one part of my commute that I have to commit to a fill up early or risk a 43 km gap between stations.
I have a 200 km commute roundtrip with hills, urban, highway mix. I actually added some 23 kms of rural driving which saved me about a half liter each way.
I put up with the fact that I have to buy gas every three or four days, I just hate stopping for it, like a detour of sorts.
