Old 12-16-2016, 04:05 PM   #21 (permalink)
Tinkerer
kafer65's Avatar
Silver - '15 Mazda CX-5 Sport
Team Mazda
90 day: 37.23 mpg (US)
I resoldered some pins and made an additional ground for the cluster. Then I climbed underneath and cleaned and reseated the speed sender at the tranny and bingo I have consistant speedo and odo function again. I've just got one headlight to fix and the aircon goes to zero pressure when the compressor comes on as repairs other than painting.
Mirror deletes, 80% grill blocks, wheel covers, 50 psi tires = 6% better MPG avg. over a year. Wheel skirts overcoming ethanol winter fuel mpg losses and more!
http://ecomodder.com/forum/showthrea...ead-30641.html
Old 12-20-2016, 10:37 AM   #22 (permalink)
skyking's Avatar
90 day: 23.82 mpg (US)
90 day: 15.1 mpg (US)
90 day: 49.05 mpg (US)
Mule - '07 Dodge Ram 3500 ST
The diesel beetle assists the Ram 1 ton truck:
Went in there easily with an engine hoist.
Much more fun getting it out with a truck mounted crane. I met the overhauler half way.
Shiny new overhaul late transmission.
2003 TDI Beetle
2002 TDI Beetle
Custom cab, auto, 3.55 gears
The Following User Says Thank You to skyking For This Useful Post:
slowmover (12-31-2016)
Old 12-20-2016, 12:33 PM   #23 (permalink)
gumby79's Avatar
little jona - '91 Dodge D 250 first gen cummins LE
Team Streamliner
90 day: 23.4 mpg (US)
Little Jona airo modded - '91 Dodge RAM 3/4 TON D 250 2×4 AUTO
Pickups
The Salted Hound Jenny. - '87 Dodge Ram 50/D-50 5sp 4X4
90 day: 20.24 mpg (US)
Jona Allison aero - '91 Dodge Ram D-250 Le
90 day: 20.76 mpg (US)
What is the new and old rpms @60mph? 1)gear chang 2) trans swap?
---port match the ehxsost manafulld on both sides .
Wrap it ... I used the extra thick wrap 1.5 rolls for man +hot side ehxsost...
Exhaust Heat Wrap
And T3 Turbo Blanket..
Have the man. hot tanked (to de rust) and 2000°+ ceramic paint.
This dropped my under hood temps to under 200° can stop at the top of a 7mile grade pulling 1000°f EGT(wide open ) pop the hood and hold on to the man. With out 3rd degree burns. The wrap reduced my 1psi point by 100° (from 600° to 500° ) = more efficient turbo. This drop was an across the bord shift.
kafer65. I make the same recommended ehxsost mods for you...
Keep the after cooler. Add a late 1st gen inter cooler/ radiator (early 1st gen too small for intercoolers per dodge/ cummins) put the aftercooler on a separate radiator ( stock is engine coolent180° intake charge =15% reduction in power from un burned fule per Cummings )my late has 15% smaller injectors and the same 160hp /400tq only difference is injectors and IC Vs aftercooler
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
The Following User Says Thank You to gumby79 For This Useful Post:
skyking (12-20-2016)
Old 12-20-2016, 12:35 PM   #24 (permalink)
skyking's Avatar
where did you source the paint?
2003 TDI Beetle
2002 TDI Beetle
Old 12-20-2016, 01:40 PM   #25 (permalink)
gumby79's Avatar
Team Streamliner
Pickups
Napa in Castle Rock, wa
Former
87' Hyundai Excel
Old 12-20-2016, 04:56 PM   #26 (permalink)
Focused on MPG
Marinator - '06 Mercury Mariner Premier
90 day: 15.45 mpg (US)
SILVER BULLET - '19 DODGE GRAND CARAVAN GT
90 day: 19.73 mpg (US)
Myrtle - Wife's JKU - '12 Jeep JK Unlimited Sport
90 day: 16.07 mpg (US)
You might look in the archives of Diesel Power Magazine, I remember reading an article about a 1st Gen Cummins that they purposely did all the work to make it more fuel efficient, and if I remember right, it was a stick shift and a dually at that but they took part of the duals off and used masking tape to tape the wheels smooth, I will see if I can find that article and hopefully post a link!
Staying Focus'd on MPG
Old 12-20-2016, 04:59 PM   #27 (permalink)
Focused on MPG
Well I just tried a google search and about 5 links down I found this!!!
http://ecomodder.com/forum/showthrea...mph-16106.html
Old 12-20-2016, 08:03 PM   #28 (permalink)
skyking's Avatar
With the new gears it was ~60 MPH at ~1750 RPM.
The OD ratio went from 0.79 to 0.74
This is a change of roughly 6.25%
This brings it down to ~1640 RPM
I use the ~ because the tachometers on these things are not precision instruments
So now I am below the peak torque of the standard cam.
I have a call in to the cam manufacturer to see what they say about peak torque.
2003 TDI Beetle
2002 TDI Beetle
Old 12-20-2016, 09:34 PM   #29 (permalink)
gumby79's Avatar
Team Streamliner
Pickups
Color me surprised..
07=1600 peek tork 24v 5.9
07.5=1500 peek tork 6.7
With your larger 33.83" tires vs31.73"
Taller gears 3.72/3.42 vs 3.55
Your spun up tighter 1750/1640 vs 1605 ( calculated including 5% extra for no lockup)
The difference is a.79/.74 vs .69 OD in the late 1st gen (91.5-93).
In my opinion your 1640 is perfect for 60mph. As the engine boogs down/lusing rpm the tork gos upto peek. Seeing as you are building a tow truck insted of a mileage monster. For me its 65mph that allows this drop to peek.
Former
87' Hyundai Excel
Old 12-20-2016, 09:37 PM   #30 (permalink)
skyking's Avatar
I run 30~31" tires 99% of the time.
I will be doing aero mods so a 65 MPH cruise will be do-able.
2003 TDI Beetle
2002 TDI Beetle
