Old 11-04-2012, 10:23 PM   #11 (permalink)
Sven7's Avatar
Boo Radley - '65 Ford F100
90 day: 13.28 mpg (US)
Bend a piece of aluminum to the shape you want the bottom to follow. Then attach the plast to it with zip ties or whatever. See basjoos' thread
I got four 4'x8' sheets for $30 off CL, so don't limit yourself to just stores. Also, elections are in like two days so go talk to your local campaign offices to see if they have extras. You can literally build grille blocks, wheel skirts and a boat tail with $20 of coroplast.
Old 11-04-2012, 10:57 PM   #12 (permalink)
deathcomesarippin's Avatar
Ill go around and ask for some election signs, ill check out the website too, if all else fail ill go to home depot. Thanks for all the help guys! Oh yeah is there a link to basjoos thread, having a hard time finding it.
1995 ford mustang. V6, auto.
Mods. 2 inch exhaust with glass pack. some throttle body mods. cut up intake box.
Aero mods. Front air dam. wing delete.
Old 11-06-2012, 08:49 AM   #13 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
BZP T-100 (2010) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 24 mpg (US)
BZP T-100 (2011) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 23.66 mpg (US)
BZP T-100 (2009) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (2012) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 25.45 mpg (US)
BZP T-100 (2013) - '98 Toyota T-100 SR5
Last 3: 25.79 mpg (US)
BZP T-100 (2014) - '98 Toyota T-100 SR5
Last 3: 23.18 mpg (US)
BZP T-100 (2015) - '98 Toyota T-100 SR5
Last 3: 23.85 mpg (US)
BZP T-100 (2016) - '98 Toyota T-100 SR5
Last 3: 17.62 mpg (US)
BZP T-100 (2017) - '98 Toyota T-100 SR5
90 day: 20.78 mpg (US)
BZP T-100 (2018) - '98 Toyota T-100 SR5
90 day: 20.19 mpg (US)
BZP T-100 (2019) - '98 Toyota T-100 SR5
BZP T-100 (2020) - '98 Toyota T-100 SR5
2012 Scion iQ - '12 Scion iQ Base
Send a message via ICQ to BamZipPow
Like this...
Dark Aero-The world's first aerodynamic single wheel boat tail!
The Following 2 Users Say Thank You to BamZipPow For This Useful Post:
Sven7 (11-06-2012), UltArc (11-06-2012)
Old 11-06-2012, 09:52 AM   #14 (permalink)
Very nice!
Old 11-06-2012, 02:28 PM   #15 (permalink)
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
Search Aerocivic.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
Old 11-06-2012, 02:51 PM   #16 (permalink)
Like This?
I'm going to 'find' a political sign to make a sample fender skirt with; but no reason not to share here. Sorry there's no picture, but imagine a skirt cut out of coroplast with the flutes running horizontally. The internal ribs are notched a fraction of an inch at each end. Then a piece of welding rod, butt-joined if necessary for length, is bent to fit and another piece is slid through the bottom flute. They are joined (I'm a little weak on detail here). The open edge of the cut coroplast is pinched together and wrapped with metal tape. Then the bottom piece of welding rod (inside the coroplast) is bent to the necessary contour.
Fastening is left as an exercise, but a washer (ground flat on the edge) could be brazed to the rod and fit into a hollow in the coroplast to make a hard attachment point.
Old 11-06-2012, 02:58 PM   #17 (permalink)
Sven7's Avatar
Originally Posted by COcyclist View Post
Search Aerocivic.
Sorry, I should have taken the 30 seconds. He has a dedicated website.
Aerocivic - Honda Civic modifications for maximum gas mileage - aerocivic.com
Here's the thread on EM
http://ecomodder.com/forum/showthrea...1-0-a-290.html
