Originally Posted by whatmaycome14
There are also apps for your phone that can "solve" triangles. Obviously you need to enter a few variables, but they will usually give you the types of answers you are looking for without having to know or remember any bit of trig.  I myself am using Triangle Solve for the iPhone.
I use android and just got and tested the free "triangle calculator" from "Google Play." I got the same results from it for the angle and rise that I got from doing the numbers myself, though only to the hundredth place (good enough) Still, I needed to measure on a flat surface or I would not know that i have just over 4" to work with, filling only 2.1" with the rise at the trailing edge of the diffuser. I need 2" more of "filler" at the back of the diffuser.
