Old 12-05-2009, 04:29 PM   #11 (permalink)
Jeep Ecomodder
JeepNmpg2's Avatar
Daddy's Jeep - '00 Jeep Cherokee SE
90 day: 19.66 mpg (US)
Mama's Kia - '06 Kia Sedona LX
Since a lot of my Jeep is aftermarket, I'm designing most of my ecomods to work with those strengths. For example, I want to make a front air dam that is removable for offroad usage, but works over my aftermarket front bumper (hell take's advantage of the multiple attachment points it has built in). If I do it right, it may also funtion as a partial grill block too!
Air Dam Thread:
http://ecomodder.com/forum/showthrea...tml#post144830
Old 12-05-2009, 08:12 PM   #12 (permalink)
Why don't you just get a front skid?
Old 12-05-2009, 08:15 PM   #13 (permalink)
Jeep Ecomodder
JeepNmpg2's Avatar
The thought had crossed my mind, but that doesn't cover as much undercarriage and it's is angled down, vice to each side. I really don't know which would be better, but from what I've read, the dam sounds more efficient.
Old 12-05-2009, 09:16 PM   #14 (permalink)
The skid goes really low. It almost covers the differential on a stock XJ
Here is mine with 2" lift
Old 12-06-2009, 12:43 PM   #15 (permalink)
Unfortunately I have no idea what the difference is highway mileage is between the skid and the air dam it had before. Like an idiot I neglected to find a long straight stretch of road to let my SGII show mileage at a constant speed. Then again, it's pretty hard without cruise control anyway.
All I do know is that my average mpg has stayed the same, 16-17.
Old 12-06-2009, 03:33 PM   #16 (permalink)
Jeep Ecomodder
JeepNmpg2's Avatar
Strange MPG's out of a Cherokee
You know, mine did the same after the first two inches of lift... but I only noticed it when I realized one of my fuel injectors was going bad (could smell fuel occasionally from the front of the vehicle). Which meant that it was staying open too long or just leaking in the combustion chamber as I never could find the actual leak. As soon as the "fuel smell" started, so did some bouts of really strange mileage readings. Like I'd gone from tanks netting an average MPG of 20-24 to 14-18. Only once after that did I get something better and made it to 20 MPG again (just barely).
LOL, I feel so pathetic over here (in Iraq) making this little run on shopping list of things to fix/add to my vehicle and unfortunately the fuel injectors are not cheap and are on top of the list (cause you can aeromod your ass off, but without an engine in good tune, you might as well be.... well, I'll leave that to the imagination of the reader of this post).
Enough of my ranting, I was on here late last night, and need sleep.
Do Rear Spoilers / Wings Help Any? Jammer Aerodynamics 27 12-30-2021 10:56 AM
Dual Fuel, electric rear wheel drive, gasoline front wheel drive bucknmusky DIY / How-to 42 12-27-2012 01:59 AM
Interest in rear wheel power (electric) bwilson4web General Efficiency Discussion 15 01-23-2011 03:41 PM
Aerodynamic lift- A real problem Hermie Aerodynamics 175 12-05-2010 07:56 PM
Rear Alignment: Drivability vs Economy Southcross EcoModding Central 11 04-22-2009 09:40 PM
