Old 06-14-2014, 06:21 AM   #61 (permalink)
la_voiture_de_courses - '03 Renault Megane Estate
OldContinents
90 day: 44.34 mpg (US)
xiao lan - '01 Audi A2
90 day: 38.88 mpg (US)
Brit iron - '92 Mini Mini
90 day: 45.5 mpg (US)
Prius - '09 Toyota PRIUS Lounge
90 day: 47.37 mpg (US)
Beemer - '06 BMW F800 ST
90 day: 53.06 mpg (US)
I was referring at fuel injection rather than power.
Thing is these small engines are tuned very much for power to offset their small capacity.
Numbers are difficult to come by : we're avant-garde here :-)
Old 06-14-2014, 07:09 AM   #62 (permalink)
Yella Peril - '80 Mercedes 240D sedan
I just fed .28 into the calculator instead of the standard .22 for engine efficiency and yes you're quite right , about a 24% decrease in fuel consumption ! I wish the Innova was available here !
Old 06-14-2014, 07:25 AM   #63 (permalink)
OldContinents
You can maybe use e-bay to buy used parts ?
Also there are some injection kits for motorcycle available online from the US that we discussed here.
FI is on my wish list too :-)
Old 06-14-2014, 08:58 AM   #64 (permalink)
Would you have a link to anything like that, especially for a 110cc engine ? I've read a little bit about FI and it would need to be amazingly simple to fit for me to have a chance !
I've been looking at the Ecotrons website , is this what you were talking about ? It looked possible .
Old 06-14-2014, 10:02 AM   #65 (permalink)
OldContinents
Small Engine Fuel Injection Kit - Small Engine EFI conversion kit
The Following User Says Thank You to renault_megane_dci For This Useful Post:
PeterS (06-15-2014)
Old 06-16-2014, 02:05 AM   #66 (permalink)
Not sure how it would compare to the OEM system fitted to the current Hondas, but sounds good.
Old 06-16-2014, 10:18 AM   #67 (permalink)
OldContinents
At least its a good starter for a much mor tunable / self learning unit like a microsquirt ...
Old 06-17-2014, 09:14 AM   #68 (permalink)
What kind of power increase would you expect with an Ecotrons FI over a carb ? Is 25% realistic ?
Old 06-17-2014, 09:52 AM   #69 (permalink)
Not unless the carb was way outta tune.
Old 06-17-2014, 10:59 AM   #70 (permalink)
P-hack's Avatar
awesomer - '04 Toyota prius
No you can't expect a big power boost. You can expect an economy boost (depending on driving style) as carbs, especially on bikes, seem to be excessively rich on the low and high end. Plus FI helps enable realtime fuel consumption feedback, so you CAN adjust your driving style.
