Old 12-06-2018, 08:36 AM   #1 (permalink)
Redline MT-LV 70W/75W gear oil for 5 speed manual Mirage (OE is 75W80)
I was poking around today looking at different gear oils. The 2014+ Mirage calls for a 75W80 gear oil. The 75W is the engine viscosity when cold, and the 80 is the viscosity when its hot. All oil is substantially thicker when cold, so getting a low first number is a good thing as it will always be thinner when hot. You just don't want it to get too thin, or you can accelerate wear in your transmission. Here is a chart to help illustrate things.
Therefore, I was looking to see if I could get a 70W80 or even 65W80. Alas, I can not find anything like that. However, what I did find was Redline MT-LV 70W/75W. You'll notice this doesn't follow the normal naming convention. So, I'm not exactly sure what to think about it. It is quite a bit thinner than Redline MTL 75W80 that many here have used.
Here are the viscosity specs of the two:
75W/80 (OE spec)
Vis @ 100°C, CSt 10.2
Vis @ 40°C, CSt 50
70W/75W
Vis @ 100°C, CSt 6.5
Vis @ 40°C, CSt 9.8
For reference, 40C is 104F. That already seems warm for a manual transmission, but I haven't measured my transmission's temperature. Anyway, at 104F, you can see the 70W/75W is 5 times thinner than the 75W80 oil. Thats a heck of a lot less churning going on. Less churning means more power and efficiency.
Anyways, I post this info because I am thinking about using it in the Mirage. I have contacted Blackstone Labs, a third party oil analysis company. I've asked them how they recommend I proceed with testing this oil with minimal risk to my transmission. I've used them many times in the past for engine oil analysis and they're very helpful.
The Following User Says Thank You to Daox For This Useful Post:
aerohead (01-23-2019)
Old 12-06-2018, 10:35 AM   #2 (permalink)
104 I can still touch. My Zf6 in the 250 gets too hot to touch, more like coolant temps or above.
Old 12-06-2018, 11:05 AM   #3 (permalink)
All the manual transmissions I have worked on with in the last 20 to 25 years all had ATF in them or special synchro manual transmission fluid (a GM thing) that looks, feels, smells and tastes a lot like ATF.
My leaf even uses ATF.
Old 12-11-2018, 01:45 PM   #4 (permalink)
I got a reply from Blackstone Labs.
We like to see at least 5,000-10,000 miles on the oil for a gear lube like that. Anything less and it's going to be difficult to gauge how well, or poorly, the transmission is actually wearing. Let me know if you have any other questions.
He didn't tell me I'm crazy or anything, so I think I am going to source the gear oil and find a time to put it in.
Old 12-13-2018, 08:34 AM   #5 (permalink)
I got another reply from Blackstone Labs. I had asked them if they had wanted to do a virgin oil analysis on the MT-LV fluid. They said no, unless I wanted it for reference. Just send in the oil at 5k miles.
Old 12-13-2018, 10:10 AM   #6 (permalink)
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
Naming convention
The T56 in the Viper used 75W/85W. I remember very specifically because there was an extended forum thread asking about alternatives, and our resident fluids guru, an oil formulator for Texaco, said the second W isn't a typo and there was something different about oils marked as such (but I can't for the life of me remember what the actual differences are).
UIUC Aerospace Engineering
www.amateuraerodynamics.com
The Following User Says Thank You to Vman455 For This Useful Post:
Daox (12-13-2018)
Old 12-17-2018, 09:02 AM   #7 (permalink)
I ordered two quarts of Redline MT-LV gear oil for my 2014 Mirage. It was a bit pricey at $42 shipped. I ended up ordering it from ebay. I had a real hard time finding it anywhere else than Redline's own site. The priced shipped from them was only a few dollars more. But, all the distributors on their site didn't even carry it. In any case, I am looking forward to trying it out.
Old 12-17-2018, 09:40 PM   #8 (permalink)
90 day: 51.82 mpg (US)
Nice. I tried sourcing that oil locally and gave up.
Old 12-18-2018, 09:02 AM   #9 (permalink)
I'm not surprised at all. I think its pretty new and nobody has it. No OEMs are really speccing it yet, so its probably not selling well yet.
Old 12-18-2018, 10:50 AM   #10 (permalink)
Stubby79's Avatar
Firefly EV - '98 Pontiac Firefly EV
90 day: 107.65 mpg (US)
Little Boy Blue - '05 Toyota Echo
90 day: 33.35 mpg (US)
BlueZ - '19 Nissan 370Z Sport
90 day: 17.19 mpg (US)
Bit off topic...but why do they rate the thickness of engine oil different from the manual trans oil? I'd have assumed, based on the numbers, that 75w is a heck of a lot thicker than 10w.
