Old 05-25-2010, 04:00 AM   #21 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
I once posted about deflectors in trucks and busses: Air deflectors on trucks/lorries.
Originally Posted by Piwoslaw View Post
Wysocki researched the aerodynamics of a long-distance bus. [...] He tested a deflector on the rear, used to scoop fresh air down onto the rear window to keep it clean, finding it increased drag by about 3%.
Once the rear deflector is removed, you have two very nice mounting supports for a Kammback. I personally would do an A-B-C test, where:
A - OEM deflector,
B - No deflector,
C - Short Kammback.
The Following User Says Thank You to Piwoslaw For This Useful Post:
aerohead (03-27-2014)
Old 05-25-2010, 11:52 PM   #22 (permalink)
gascort's Avatar
Gascort RIP - '93 Ford Escort Wagon
90 day: 43.01 mpg (US)
WifesCruze - '11 Chevrolet Cruze LT
90 day: 31.1 mpg (US)
skibum is correct if I recall correctly; remove the fin and you will draw all sorts of exhaust gas into the back window. No biggie if you're aware of it though.
I'm pretty sure removing it will help your mpgs. I like the debate on this though!!!!
Gasoline, Wind, Solar, Gravity Hybrid-to-be! http://www.scientificmethodfueleconomy.blogspot.com/
Old 05-27-2010, 05:48 PM   #23 (permalink)
A - OEM deflector,
B - No deflector,
C - Short Kammback.
That's set up to direct air straight down, so of course it's going to increase drag. But what if you angled it the way you'd angle a kammback?
Old 03-26-2014, 11:09 PM   #24 (permalink)
Help please
Hello Quattro, welcome to the site.
Do you have any pictures of this deflector?
Hi, first time here, regarding this deflector, I need to find the manufacturer of it.
I've got the same on my 4R, happened that I've lost three of the four screws in rough roads.
Hope to find them as spare parts.
Can you help me?.Thanks
Old 09-20-2014, 09:56 AM   #25 (permalink)
Smile 4runner rear wind deflector PARTS
Hi there, unfortunately while going out of my garage, one of the two bases where the deflector was mounted, got broken.
ANY CLUE of manufacturer Co. name???
Thanks.
Reviving a 2000 Honda Insight "beater" Red Hybrids 215 08-10-2017 08:35 PM
Window trim hurting aerodynamics? And a solution for my rear doors. Sean T. Aerodynamics 36 10-19-2008 08:58 PM
ScanGauge Rear Window Display? cfg83 Instrumentation 4 09-26-2008 01:31 PM
tuft testing on 93 Sentra back window jim-frank Aerodynamics 5 06-16-2008 05:59 PM
Rear window fairing (roof extension) apgrok1 Aerodynamics 14 03-12-2008 01:33 AM
