Old 06-08-2012, 09:51 PM   #1 (permalink)
The Dirty330 Modder
Gealii's Avatar
CruzeRS - '15 Chevy Cruze LT RS
90 day: 41.29 mpg (US)
Turtle To replace or not to replace the clutch
Here's my situation i just graduated high school and wanted a high mpg car to travel to college everyday. I have a 99 ford zx2 with 186k miles. It is not to bad on rust for being a northern car. I love the car and even with a budget of 3k usd i feel i could not replace the car for something of equal value once the clutch gets replaced.
The question is should i go ahead and have the clutch replaced? I'm going to have a mechanic do all the work to replace it. I have not looked at prices but figuring $600-1000
Forgot to mention the car has new break lines, battery, alternator, has no check engine lights and e brake still works
"The only real mistake is the one from which we learn nothing."
- Henry Ford
Old 06-08-2012, 09:56 PM   #2 (permalink)
Volt, gas only - '12 Chevrolet Volt Premium
90 day: 38.02 mpg (US)
Volt, electric only - '12 Chevrolet Volt Premium
90 day: 132.26 mpg (US)
Yukon Denali Hybrid - '12 GMC Yukon Denali Hybrid
90 day: 21.48 mpg (US)
Keep it, save your money for another day. At 13 years and 186k it may come sooner than expected.
Old 06-08-2012, 10:12 PM   #3 (permalink)
Pishtaco
SentraSE-R's Avatar
Mean Green Toaster Machine - '06 Scion xB
90 day: 48.92 mpg (US)
Assuming your clutch is slipping, yes, you should replace it.
Darrell
Boycotting Exxon since 1989, BP since 2010
Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac? George Carlin
49.5 mpg avg over 53,000 miles. 176% of '08 EPA
Best flat drive 94.5 mpg for 10.1 mi
Longest tank 1033 km (642 mi) on 10.56 gal = 60.8 mpg
Old 06-09-2012, 12:12 AM   #4 (permalink)
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
Most of us would assume that if you are planing to replace a part then it needs to be replaced, but you didn't say how bad it was slipping, some clutches last 500,000 miles if used lightly, but if it's not broke then don't fix it.
There is also the chance that a cheap mechanic is going to take some short cuts like not milling the fly wheel, that can lead to clutch chatter, or that they put in a race clutch and those grab much harder then people like and make your car hard to drive.
Old 06-09-2012, 08:15 AM   #5 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
If it's slipping, yes.
Ask around for prices.
I'd expect them to be less.
Old 06-09-2012, 09:15 AM   #6 (permalink)
The Dirty330 Modder
Gealii's Avatar
I've been reading more on what it feels like for the clutch to be actually slipping. I just got the car off my brother a couple weeks ago for $800 and he said the clutch needed to be replaced by the end of summer ( just learned how to drive a 5speed ). but reading up on how to test a slipping clutch it doesn't really seem that bad. The rpms still climb evenly with the speed even at higher rpms.
- Henry Ford
Old 06-09-2012, 09:38 AM   #7 (permalink)
Eco-ventor
jakobnev's Avatar
Princess - '92 Mazda MX-3 GS
House of Tudor
Team Mazda
90 day: 53.54 mpg (US)
Shirubāarō (*´ω`*) - '05 Toyota Prius Executive
90 day: 54.88 mpg (US)
Blue Thunder - '20 Hyundai IONIQ Trend PHEV
Plug-in Hybrids
90 day: 587.16 mpg (US)
Send a message via MSN to jakobnev
I got my last car cheap partially because the clutch was worn out..
..i drove it five more years before it started slipping.
Old 06-09-2012, 09:55 AM   #8 (permalink)
The Dirty330 Modder
Gealii's Avatar
which is what I'm thinking is that it's just worn cuz of the test i did, so assuming what every1 else said ill just keep my money til it does actually start to slip instead of getting another car
- Henry Ford
Old 06-09-2012, 01:39 PM   #9 (permalink)
Ryland's Avatar
I've met a hand full of people who think that their clutch needed to be replaced because it didn't grab like a race clutch does and if you are driving your car on regular streets or in any stop and go traffic EVER you don't want it to grab like a race clutch, but you will notice it slipping when it's worn out and there is a good chance that you will never notice it slipping unless someone drove it really hard before you got it.
Old 06-09-2012, 02:01 PM   #10 (permalink)
euromodder's Avatar
Then it doesn't seem to be slipping.
Clutches obviously wear down over time, and then start being a bit less smooth, or start to catch earlier on when you release the pedal again ... that's wear, but it doesn't mean it's shot.
You won't wear down a clutch with a test
It takes prolonged abuse before it'll fail.
Just remember it's only there to shift gears, getting started from a stop, and do some REALLY SLOW manouvring.
Try to make smooth shifts without being on the clutch for too long, and it'll last a long, long time.
clutch replace
