Old 08-15-2008, 06:59 PM   #1 (permalink)
SeeOurWrecks - '91 Honda CRX Si
90 day: 35.59 mpg (US)
Accord_Inspire - '93 Honda Accord EX
90 day: 24.56 mpg (US)
Honda Accord configuration
I'm pretty happy with the numbers I have so far. Some further tweaking may be needed, but I thought I'd get this up there at least for posterity.
This is on a 93 EX coupe, I've made modifications but they shouldn't make much of a difference.
VSS: 8208
ms/gal: 196692124
tank: 17.1 gal or 17100
Use these numbers as a starting point for 90-93 accords, all trims. They are all versions of the f22a engine, they all use the same injector and the same vss.
Parting out 1988 Honda Accord Tango Charlie For Sale 12 08-31-2009 05:15 PM
01 honda accord aero-advice chilimac02 Aerodynamics 17 09-09-2008 03:48 PM
Conversion: 91 Honda Accord w/ HHO anox195 EcoModding Central 36 08-21-2008 07:00 PM
Honda as a green company - perception overshadowing reality? atomicradish EcoModding Central 11 07-19-2008 04:36 PM
Honda Accord 96 LX Sedan Improve MPG. rjuki Off-Topic Tech 6 04-25-2008 03:14 PM
