Old 09-03-2017, 08:46 AM   #31 (permalink)
Palladium is at like a 16 or 17 year high.
Platinum is coming off like a 5 year low of 900 an ounce. I bought a few ounces, so I'm watching the price.
Xist (09-03-2017)
Old 09-15-2017, 05:10 AM   #32 (permalink)
90 day: 30.54 mpg (US)
I tried to find more information on this method.
3,000 miles before code: https://priuschat.com/threads/acid-b....166554/page-3
12,800 miles before code: https://www.tacomaworld.com/threads/...d-wash.241619/
18 months and no code: (All Years) Catalytic Converter Citric Acid Bath P0420 - Subaru Forester Owners Forum
Almost 30,000 miles without a code: P0420 / P0430 and a "Hail Mary Pass" (the "cat washing" thread) - Page 12 - Toyota Tundra Forums : Tundra Solutions Forum
BamZipPow ran it through the dishwasher and has not had a code for 41,000 miles: http://ecomodder.com/forum/showthrea...-do-23483.html
480 miles and disappered: https://www.bobistheoilguy.com/forum...topics/3391904
Tried a few things, without clear results: https://forum.ih8mud.com/threads/cat....833570/page-2
Attempted, but did not report back: (All Years) P0420 Catalytic Citric Acid Bath (How To) - Subaru Forester Owners Forum
Who knows how accurate any of this is, but there is indication that 50% of people who try this see clear benefits, but unfortunately, it seems like hardly anyone followed the directions perfectly.
California98Civic (09-15-2017)
Old 09-15-2017, 05:24 AM   #33 (permalink)
Try hydrochloric.
Old 09-15-2017, 11:43 AM   #34 (permalink)
This seems to indicate HCL would not provide the results I desire: Using Dilute HCl/Cl to Process Catalytic Converter - Gold Refining Forum.com
Old 09-15-2017, 12:52 PM   #35 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
... 18 months and no code: (All Years) Catalytic Converter Citric Acid Bath P0420 - Subaru Forester Owners Forum...
I think that Subaru link is one of the dudes I was copying in my citric acid bath cleaning. FWIW, thirteen months later and no emissions related codes (no codes at all, acutally). But I did not have a code to begin with. I had reason to suspect my 1998 OEM catalytic converter might fail emissions and wanted to be prepared. I passed emissions, barely. Then I cleaned it.
Last edited by California98Civic; 09-15-2017 at 12:53 PM.. Reason: thirteen months, not fifteen.
Xist (09-15-2017)
Old 09-25-2017, 01:58 PM   #36 (permalink)
California98Civic was kind enough to share his cleaning supplies with me; I bought a 16 quart stainless steel stock pot for my larger Accord cat and put it on a hot plate for 10 hours. Unfortunately, the larger pot was still not deep enough, either I needed a much larger pot, much more water, and much more powder, or a turkey fryer pot. It did something, the water turned black. The water did not cover the electrolyte honeycomb, so I flipped it over halfway through, although since the sensors is in the middle I could have ignored the back half. Curiously, it ate one of my gaskets.
I did this at 179,270 miles.
http://ecomodder.com/forum/attachmen...1&d=1506362279
California98Civic (10-12-2017)
Old 09-25-2017, 02:25 PM   #37 (permalink)
Hmmm, HCl might work a little too well.
Old 10-12-2017, 07:27 AM   #38 (permalink)
Cyborg ECU
... The water did not cover the electrolyte honeycomb, so I flipped it over halfway through, although since the sensors is in the middle I could have ignored the back half. ...
[imgl]http://ecomodder.com/forum/attachment.php?attachmentid=22756&stc=1&d=15063622 79[/img]
This is great. I am glad there has been no CEL for nearly 2000 miles, too! My pot was also on the small side. But the honeycomb was completely submerged for me. And I used a ladel or something to move sort of baste the top of the honeycomb. Did you monitor solution temperature at all? It is not supposed to boil, but they recommend a pretty high temperature.
Old 10-31-2017, 11:50 AM   #39 (permalink)
Unfortunately, I forgot to bring my infrared thermometer, but it was never boiling when I checked on it.
Did the acid eat the coating in your pot? Mine turned green, I cleaned it, and now it is rusted!
Old 05-17-2018, 05:29 PM   #40 (permalink)
Cyborg ECU
Cleaned O2 sensors with this method
Decided to clean my O2 sensors with this same method, rather than using gasoline on the sensors. I figured if the light acid wash was good enough for the catalytic converter, then it should be fine for its partners in crime (the O2 sensors). I used a half gallon of tap water instead of distilled. I cooked for two hours, scrubbing occasionally with an old tooth brush. Pics:
BEFORE (upstream on left, downstream on the right):
The downstream one on the right was throwing the P0420 code.
Submerged the contact area of the sensor only:
After cooking (no boiling) outside for 2 hrs, compare the above and below photo to notice the flakes of yellow and black in middle of the pot that have gathered there due to stirring:
AFTER (upstream on left, downstream on the right):
Took it for a spin of maybe 15-20 miles. All seems good, Felt like I got into DFCO easier, sooner, but that could easily be confirmation bias. Butt dyno stuff, that.
ID:	24211   Click image for larger version
ID:	24212   Click image for larger version
ID:	24213   Click image for larger version
RedDevil (07-07-2018)
