10-31-2012, 05:02 PM
#41 (permalink)
I have used a full grille block on my truck, and it helped tremendously with warm up time. I have been too busy to complete my louver set, but now I will have time to "get all over it".
Thanks for the thread and inspiration.
2003 TDI Beetle
2002 TDI Beetle
Custom cab, auto, 3.55 gears
11-01-2012, 02:42 AM
#42 (permalink)
The grill shutters came in today.
11-24-2012, 02:36 PM
#43 (permalink)
Grand Imperial Poobah
Here are a couple of links to real shutters. They are made to be mounted on radiators, but one could mount them into a custom grill.
I would use 12v linear actuators if I was installing these on a car or other small vehicle.
They need to be lubed every 20k miles. Not really practical for heavy duty trucks as a active grill. So you won't find one of these in our next-generation Class 8 rig. But we will have our own active grill.
http://delpprintingandmailing.com/bw...FDs/sb1006.pdf
http://delpprintingandmailing.com/bw...s/Shutters.pdf
Bob Sliwa
"Like a Midget at a Urinal, I knew I was gonna have to stay on my toes......."
http://www.airflowtruck.com
The Following 4 Users Say Thank You to Shepherd777 For This Useful Post:
11-24-2012, 03:13 PM
#44 (permalink)
EcoMod Proof of Concept
here are a couple of after market ones to consider:
larger one is $104
HighWing LLC
smaller one is $98
HighWing LLC
2000 Insight MT 106K Citrus A/C
The Following 4 Users Say Thank You to WD40 For This Useful Post:
11-24-2012, 07:59 PM
#45 (permalink)
The Following 2 Users Say Thank You to CigaR007 For This Useful Post:
11-24-2012, 09:22 PM
#46 (permalink)
halos.com
Originally Posted by Cd
Why not copy what AndrewJ did with his Civic, but have it operated by a servo from an R/C plane ?
The signal to open or close the mechanism could be temperature controlled to trigger at a certain temperature .
It seems as though an easy way to do this would be to just wire into the power source for the electric fan. As the engine temperature rises and kicks on the fan, this would also send the signal that opens the shutters .
I was thinking along the same lines. I've got a set of blinds from one of our windows (previous owner's cats shredded the cords), and thought I'd fab a couple of end brackets, get some piano wire to serve as pivots and use a cabin mounted switch to a servo motor to flip the blinds.
I'm even thinking one step further, and fabbing a modified grill. It will have to protrude a bit, so when the blinds flip, they form an angled surface (maybe 60* from horizontal) to guide the air over the hood better.
11-25-2012, 12:34 AM
#47 (permalink)
Thin plastic or metal window blind slats wouldn't be strong enough for the air pressure from a moving vehicle.
A classic grille shutter application. 1927 Essex Super Six boat tail speedster | Flickr - Photo Sharing!
Thermally controlled so they open as the engine heats up.
The Following User Says Thank You to Galane For This Useful Post:
07-21-2013, 12:37 AM
#48 (permalink)
Grill shutters are retro fitted on to an older vehicle.
No I don't have a way to control them.
07-24-2013, 04:52 PM
#49 (permalink)
Cruze shutters on eBay?
OMG I don't have enough posts to post an image...UGH!!!
Chevy P/N 95991352
I wonder if life is this easy?
Could one cheaply order the cruze shutter box and transplant it?
2003 Mini Cooper S Works
+ Full underbody panels, front lip and rear bumper vents.
The Following User Says Thank You to MiniAero For This Useful Post:
07-24-2013, 06:39 PM
#50 (permalink)
The Following User Says Thank You to WD40 For This Useful Post:
