Old 08-08-2012, 10:16 PM   #21 (permalink)
Zerohour's Avatar
Pooparu - '01 Subaru Outback Limited
90 day: 28.12 mpg (US)
Cop Car - '94 Chevy Caprice Interceptor 9C1
Last 3: 18.48 mpg (US)
Mini - '11 Mini Cooper
90 day: 37.63 mpg (US)
Gramps - '95 Subaru Legacy Postal
90 day: 23.18 mpg (US)
I always thought of using door actuators and a universal radiator fan controller (for electric fans). Have the fan controller open/close the door locks based on engine temp. You would still need to build the opening mechanism.
The Following User Says Thank You to Zerohour For This Useful Post:
WesternStarSCR (10-29-2012)
Old 08-09-2012, 02:39 AM   #22 (permalink)
Red Egg - '95 Ford Aspire
90 day: 38.51 mpg (US)
Dodge SRT-4 - '04 Dodge Neon SRT-4 2.4L Turbo
90 day: 26.24 mpg (US)
I like all the approaches as a whole, and each one may work better for some vehicles and not others. You don't want your oem cooling fans turning on earlier or staying on longer than they do without a new grill shutter mod. The e-fans eat mpg on their own. I always wanted to just shut off the seconday fan for my a/c once i was rolling 30mph or better, especially if its really hot the regular fan may be on too anyway and pulling air thru the condenser already
Old 08-09-2012, 03:32 AM   #23 (permalink)
Many cars in the 1920's and 1930's had thermostat controlled shutters in front of the radiator, in some cases the shutters were also the grille. Depending on the design of the car the shutters were horizontal or vertical.
Look up photos of 1930's Packards. They used two panels of vertical chromed louvers. With the car at rest and engine off and cool, the grilles look like solid metal sheets with some vertical grooves.
Old 08-09-2012, 07:37 AM   #24 (permalink)
Do more with less
OD - '05 Ford Econoline
90 day: 18.64 mpg (US)
90 day: 49.71 mpg (US)
90 day: 28.08 mpg (US)
Question, If you are worried about running a cooling fan to save fuel, why are you then running the air conditioning?
I barely see any difference when running an electric load but when I turn on the AC, I get anywhere from 2 mpg in my Econoline to 5mpg in my minivan.
Be careful cutting off your cooling fan with your ac condenser on. The money you save in gas may be going to buy you a new engine or transmission. Just saying....
Noah Webster, 1787
Old 09-01-2012, 06:19 PM   #25 (permalink)
While they are just now arriving on the streets, the new Dodge Dart/Alfa Romeo also has a shutter system in the grill. I was a detailer for Chrysler at the shows this year. We had first a pre production show car ( only the motor under the hood and nothing hooked up) that we used on a display to show the new model. By Cleveland, we had actual running test cars that could be driven onto displays and a cutaway..
Old 09-01-2012, 06:22 PM   #26 (permalink)
Not a great picture, but here is a view of the shutter system and location
2013 Dodge Dart | All New compact that's everything but compact | Dodge
The Following User Says Thank You to slime For This Useful Post:
WesternStarSCR (10-08-2012)
Old 10-26-2012, 01:57 PM   #27 (permalink)
Its getting cold out so I broke down and got the broil master grill shutters a few days ago, should be here any day now.
Old 10-26-2012, 02:08 PM   #28 (permalink)
The PRC.
Exploded view of Chevy Cruze "shutter" grille [w/video]
So simple, never thought I would see such a thing coming from an OEM these days.
Looks easy enough to build up a stack of these as needed for use in an existing vehicle.
Could it be too good to be true?
I thought the best grill to block was the upper one, but this shows the shutter only operating on the lower one ?
The Following User Says Thank You to Arragonis For This Useful Post:
Old 10-27-2012, 12:05 AM   #29 (permalink)
Upper is better, but a lower grill block is better than no grill block.
Old 10-29-2012, 04:02 AM   #30 (permalink)
The PRC.
Pondering further I think we have seen these types of blocks here before haven't we - sliding covers with grill holes spring to mind, operated by cable and returned with a spring or a cable going in the opposite direction. Something using a warm air style heating vent may be possible too.
