Old 03-04-2008, 08:44 PM   #11 (permalink)
Red
Red's Avatar
I'd put it on the same level as driving a top-less Jeep. You have to do it atleast once in your life.
Random factoid for any TJ or YJ owners looking at this. The front Al radiator pan for the Insight has mounting holes more or less the exact width as our frame rails. Was bored of doing Discrete Math, so I found out that one could mount it to the front frame snubbers, lie it against the steering box and you'd have a front air dam angled back around 35-40 degrees that would covers almost all of your steering linkage. Before I mount them to Rommie I think I'm going to experiment with them first on the Heep.
Old 03-04-2008, 09:35 PM   #12 (permalink)
The Civic - '00 Honda Civic DX
90 day: 37.05 mpg (US)
Originally Posted by Red View Post
:P Yep its my "beater" adhering to a loose definition of the term.
Stubborn to a fault. Thanks all. I've been taking pictures as I go, just haven't had time to clean them up and post them online. Got a weeks worth of tests next week so I've been stretched for time lately. But so far its been fun.
From my understanding the engine of the Insight weighs around 120lbs and the battery pack around 50lbs or so, so the IMA drivetrain excluding the tranny would be around 170lbs give or take. Not sure on the weight of a z1 engine but you would be better off in gasoline power but not in the weight department with such a swap. Engine bay room would be tight though with a 4 banger instead of the 3. The electric motor is fairly thin, I want to say its housing is about 2" wide. I think you could probably offset the tranny some more to the drivers side, but assuming you kept everything mounted the way it is, there wouldn't be room or it would be a really tight fit to get everything in there.
Though if you could give me the length of a z1 + tranny I could give you a definite yes or no.
Well I know of some drag racing types who put a K20 in one...wait it was a tube-frame redux. :P
Honestly I'm shocked about the battery pack being so light... I'm rethinking the weight savings now.
Old 03-04-2008, 10:19 PM   #13 (permalink)
budomove's Avatar
Ze Future Beam - '00 honda insight
90 day: 66.23 mpg (US)
You would need to reverse the z1, since the transmission is on the drivers side on the insight. the mounts would likely all need to be totally fabricated, since the mounts are not in typical places on the insight.
2000 Honda Insight 5spd Silver 63.9 lmpg
Old 03-04-2008, 10:52 PM   #14 (permalink)
OCD Master EcoModder
brucepick's Avatar
Outasight - '00 Honda Insight
Gen-1 Insights
90 day: 54.18 mpg (US)
Wow - what a find.
And it looks like you're doing a fine and thorough job straightening out the car.
Good luck with it!
Coast long and prosper.
Old 03-04-2008, 11:08 PM   #15 (permalink)
Depends on the Day
RH77's Avatar
Teggy - '98 Acura Integra LS
Sports Cars
90 day: 32.74 mpg (US)
IMA - '10 Honda Insight EX
90 day: 34.76 mpg (US)
Tessie - '06 Acura TSX Base
90 day: 28.2 mpg (US)
Welcome + ...
Hey Red, welcome to EM!
What a great find -- looks like a little TLC and off it goes.
I have to commend you for looking for a daily driver outside of the TJ. I will admit that a solid Jeep is good for purpose driven off-roading, and to maintain that hobby, but expensive as a DD.
Have fun with both vehicles, and again Welcome. Here, you'll find some Jeep members that "understand", so to speak
Best FE to ya!
RH77/Rick
“If we knew what we were doing, it wouldn't be called research” ― Albert Einstein
_
_
Old 03-05-2008, 11:31 AM   #16 (permalink)
johnsn's Avatar
Sweet deal!
I have a 2001 Insight. I love it.
Yes it's fairly gutless, that's why it gets such good mileage.
Fix it up and enjoy.
Check with Honda for any recalls. You might get some free parts.
john
Old 03-15-2008, 08:21 PM   #17 (permalink)
Red
Red's Avatar
Day 1 of Spring Break, pulled the LAF Sensor. Looked like this
I don't see anything remotely serviceable...Save for the carbon dust on the end, I don't see any real fouling or anything that looks like it could have killed the sensor. Old age I guess did it in. Going to dig out my ElmScan tmw and hook it up to see if the 02 is doing anything at all. Else time to call up Majestic Honda again.
Old 03-15-2008, 08:59 PM   #18 (permalink)
Red
Red's Avatar
Amazingly enough I get wireless outside.....
So I hooked up my ElmScan got the following data out of it
S1B1 = 1.085v no matter what
S2B1 = 0.835v @ idle then drops as the RPMs Increase 0.055 @2k+
Old 03-15-2008, 09:43 PM   #19 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
How does that compare to what the manual says on the subject? You might just need a new one, na?
Old 03-15-2008, 10:18 PM   #20 (permalink)
Red
Red's Avatar
Book says death. The sensor should show some voltage change once warmed up. Post cat is operating within range. Pre is dead in the water.
honda insight, modifying, rebuilding
Honda IACV explained TomO Off-Topic Tech 16 12-21-2015 01:49 AM
Places to get OEM Honda Parts TomO Off-Topic Tech 10 06-02-2009 01:56 PM
Honda insight, doing research, interesting trends NoCO2 General Efficiency Discussion 15 05-06-2008 07:36 PM
