Old 02-24-2018, 04:34 PM   #11 (permalink)
Corvette
It would have been good if they had radius'd the trailing edge of the wheel opening to help bring the flow parallel to the outer flow,rather than collide with it.
Old 02-24-2018, 07:09 PM   #12 (permalink)
IGL - '04 Saturn Ion
Team Saturn
90 day: 56.19 mpg (US)
Something like that would be great if I had a longer fender to roll in, but I’ve only got about 6” of fender...
My current Ecotec project...
My last Ecotec project...
Old 02-24-2018, 07:14 PM   #13 (permalink)
Seems like a lot of work for a questionable result. But I can imagine that any rounding of that edge will help reduce wake.
Old 02-24-2018, 07:14 PM   #14 (permalink)
If you do it, please do at least an A-B test. Probably no going back to A on this one.
Old 02-26-2018, 10:30 AM   #15 (permalink)
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
BMW saw enough benefit from relieving wheel well pressure to implement a vent (same function as the rolled fender, evacuation of higher-pressure air) on the X5.
UIUC Aerospace Engineering
www.amateuraerodynamics.com
The Following User Says Thank You to Vman455 For This Useful Post:
aerohead (03-03-2018)
Old 02-26-2018, 01:56 PM   #16 (permalink)
Agreed that the front tire to door hinge line is critical.
I think this is a fiberglass Hebmuller, but you can get the same effect by grafting a Superbeetle nose onto the back. Gary Emory did it in the 90s. That would be a good picture to dig up. He did it to a 1952 with an MG-TD windshield!
Old 02-27-2018, 02:46 AM   #17 (permalink)
Team Saturn
It’ll be very difficult to get anything resembling a valid A-B test of the fender mod... I figure that if I mod the trailing edge, I’ll do a pair of fenders and swap them on... problem is, it takes about 90 min a side due to the other stuff that needs removed... weather would change a lot in half a day...
