Old 02-26-2018, 12:35 PM   #1 (permalink)
90 day: 39.72 mpg (US)
90 day: 58.66 mpg (US)
Just saw this on my local Craigslist
https://potsdam.craigslist.org/mcy/d...471784479.html
Here's an interesting opportunity and your chance to own a Tri-magnum (reverse trike). This design was was built years ago using plans available from the Feb 1983 Edition of Mechanix Illustrated. This example was mostly completed but should be considered a project. It's on a rolling chassis but needs to be finished. It's a solid build and stands roughly 42 inches tall, and about 14 feet long. The Goldwing underneath was disassembled and is basically non-functional. The good news is this Trimagnum comes with a nice, complete, 1980 Goldwing 1100cc (with clean paperwork) that will slide right in place of the non-functional one. The 1980 Goldwing has had a single barrel carb adapted to it for reliability - however - the original 4 carb unit is included. Google "Trimagnum" to learn more and see what others have done with theirs. Youtube videos of these are not difficult to find. The performance of a Trimagnum is basically limited only by the donor bike used. How wild do you wanna get with this spaceship????
Probably not all that aerodynamic, but neat. Thoughts?
The Following 3 Users Say Thank You to Ecky For This Useful Post:
aerohead (03-03-2018), BamZipPow (03-01-2018), Xist (02-26-2018)
Old 02-26-2018, 12:41 PM   #2 (permalink)
I think he's an EMer or at least a lurker.
Old 02-26-2018, 04:14 PM   #3 (permalink)
I looked up that design earlier today, too bad that the body does not taper more because of those rear taillights and the back half of the front wheels coverings isn't blended into the body.
If it were my time and money I'd rather invest in a Lotus Esprit barn find project car and at least have a remote hope of recouping my money.
I wonder what it would take to bring this Elan back to life.
https://www.ebay.com/itm/1968-Lotus-...JY2gs9&vxp=mtr
If you have to ask, you cannot afford it?
I mean, if you are going to be playing with fiberglass, play big, right?
Old 02-26-2018, 04:32 PM   #4 (permalink)
Oh, I'm not intending to buy, just thought I'd share. I'd never seen anything like it.
Old 02-26-2018, 04:49 PM   #5 (permalink)
I can't decide if I should give or take away points for his use of Vega tail lights.
Old 02-26-2018, 09:36 PM   #6 (permalink)
Primer is still paint!
ChopStix's Avatar
90 day: 32.46 mpg (US)
I used to own one. Though mine was done a bit different. But the Honda Goldwing conversions (tri-magnum conversion kit) used to be very popular back in the 80's. Here's some info on them.
https://uncommonmotors.com/tri-magnu...ld-wing-power/
And a google search provides a ton of pictures
The Following User Says Thank You to ChopStix For This Useful Post:
Old 02-26-2018, 10:18 PM   #7 (permalink)
Thoughts?
Thanks for asking. Compare to
Robt. Q. Riley X-3
Fiberfab Aztec
Blackjack Zero
The XR-3 is front or rear drive (or through-the-road hybrid). The Scarab was based on a motorcycle, but you could revert back seasonally. The Blackjack Zero has a flat four in front.
My money is on the Arcimoto FUV.
Old 02-27-2018, 06:36 AM   #8 (permalink)
Winsight - '06 Honda Insight
Gen-1 Insights
90 day: 72.19 mpg (US)
I saw one the other week as well!
https://charlotte.craigslist.org/cto...503901964.html
Pretty funky, too kit like for me however.
ID:	23612   Click image for larger version
Old 02-27-2018, 08:39 AM   #9 (permalink)
Master Novice
elhigh's Avatar
Josie - '87 Toyota Pickup
90 day: 29.5 mpg (US)
90 day: 49.47 mpg (US)
I'm going to go with the non-EM suggestion: slot in a 1987-up GW with the six cylinder engine. That gets you a reverse "gear."
Old 02-27-2018, 08:58 AM   #10 (permalink)
Originally Posted by ChopStix View Post
From that search here is one that almost slipped between the cracks.
The story so far...
Above is a shot of a Turbo Phantom which was designed and built in the late 70's.
The Following 3 Users Say Thank You to kach22i For This Useful Post:
aerohead (03-03-2018), BamZipPow (03-01-2018), freebeard (02-27-2018)
