Old 11-25-2012, 09:42 AM   #1 (permalink)
Diesel_Dave's Avatar
White Whale - '07 Dodge Ram 2500 ST Quad Cab 2wd, short bed
90 day: 37.68 mpg (US)
Rolling Resistance Data for >1,000 tires
Forgive me if someone already posted this, but I came across the motherload of tire rolling resistance data. This .pdf, put out by the Rubber Manufacturers Association in 2009 has rolling resistance data for over 1,000 different tires (tables start on page 47). It also has a wide range of sizes (13 to 22 inch).
http://www.rma.org/rma_resources/gov...20Analysis.pdf
Diesel Dave
My version of energy storage is called "momentum".
My version of regenerative braking is called "bump starting".
1 Year Avg (Every Mile Traveled) = 47.8 mpg
BEST TANK: 2,009.6 mi on 35 gal (57.42 mpg): http://ecomodder.com/forum/showthrea...5-a-26259.html
The Following 28 Users Say Thank You to Diesel_Dave For This Useful Post:
2000neon (11-25-2012), 2speedranchero (01-18-2013), 3-Wheeler (11-25-2012), AndrzejM (07-12-2013), astra74 (11-25-2012), California98Civic (07-08-2013), Cd (11-25-2012), christofoo (01-10-2013), Daox (11-25-2012), fusion210 (11-27-2012), gone-ot (11-25-2012), hate2loveford (01-22-2013), kennybobby (11-25-2012), MetroMPG (11-26-2012), nemo (11-25-2012), Nevyn (07-09-2013), Piwoslaw (12-26-2012), RH77 (11-25-2012), rmay635703 (11-25-2012), Ryland (11-25-2012), serialk11r (11-25-2012), sid (11-29-2012), slowmover (11-25-2012), Sven7 (11-25-2012), Vekke (11-25-2012), WD40 (11-25-2012), wmjinman (01-10-2013), YukonCornelius (07-08-2013)
Old 11-25-2012, 10:53 AM   #2 (permalink)
Southern Squidbillie
Many thanks for that find. Here are some observations that i lifted from the report:
"Rolling resistance is due to hysteresis, which is a function of tire chararacteristics such as dimensions, geometry, composition, and thread depth.
The RRC of a tire decreases as the tire wears; this reduction is due in part to the reduction in thread depth.
Rolling resistance is also affected by operating conditions such as load, temperature, and inflation pressure.
The RRC of an underinflated tire is substantially higher than that of a tire that is properly inflated.
A reduction in RRC of 0.001 is expected to increase fuel economy by 1 to 2 percent. The actual increase will be closer to 1 percent for low-RRC tires and urban driving, and closer to 2 percent for high-RRC tires and highway driving."
The probability distribution curve showed the average RRC to be about 0.010 over a range from 0.007 to 0.017.
e.g. Michelin 255/65-17 LTX A/S @ 0.00745
The Following 3 Users Say Thank You to kennybobby For This Useful Post:
California98Civic (07-08-2013), MetroMPG (11-26-2012), niky (07-08-2013)
Old 11-25-2012, 11:11 AM   #3 (permalink)
Sven7's Avatar
Boo Radley - '65 Ford F100
90 day: 13.28 mpg (US)
Nice find.
For those looking for the meat and potatoes, the Appendix 3/4 of the way down has specific tires- brand, model, size- listed together.
Should we sticky this?
Old 11-25-2012, 12:32 PM   #4 (permalink)
Depends on the Day
RH77's Avatar
Teggy - '98 Acura Integra LS
Sports Cars
90 day: 32.74 mpg (US)
IMA - '10 Honda Insight EX
90 day: 34.76 mpg (US)
Tessie - '06 Acura TSX Base
90 day: 28.2 mpg (US)
Excellent report!
A big thanks for finding and posting it
-RH77
“If we knew what we were doing, it wouldn't be called research” ― Albert Einstein
_
_
Old 11-25-2012, 12:37 PM   #5 (permalink)
...beats walking...
Wow, now if only all that data were available in spreadsheet format (ha,ha)!!!
Old 11-25-2012, 12:37 PM   #6 (permalink)
90 day: 19.36 mpg (US)
Looks like limited to cars and 1/2T pickups. Don't see LOAD INDEX correlating to 3/4T and 1T pickups (which have been fuel economy exempt).
Great find!!
Them Rummers done a good job.
Old 11-25-2012, 01:11 PM   #7 (permalink)
90 day: 39.72 mpg (US)
90 day: 58.66 mpg (US)
Found my front tires (Michelin Destiny) in 2 different sizes, both have a RRC of 9.7.
I'll probably use this next time I'm in the market for tires.
Old 11-25-2012, 02:55 PM   #8 (permalink)
EcoMod Proof of Concept
WD40's Avatar
WD-40's Insight - '00 Honda Insight
Gen-1 Insights
90 day: 56.04 mpg (US)
WD-40's Mirage - '15 Mitsubushi Mirage ES
90 day: 46.05 mpg (US)
WD-40's Sonata Hybrid - '17 Hyundai Sonata Hybrid Limited
I converted it to excel
here it is on Google Docs no sign in required
2000 Insight MT 106K Citrus A/C
The Following 2 Users Say Thank You to WD40 For This Useful Post:
hate2loveford (01-22-2013), Nevyn (07-09-2013)
Old 11-25-2012, 03:07 PM   #9 (permalink)
Great find!!
There are actually quite a few in that category. My current tires have a load index of 113 (2,535 lbs). There are 87 tires in that list with that load index or higher. There's even one in there with a load index of 120 (3,086 lbs).
I fixed that "Rummer Manufacturers" typo too :-)
Diesel Dave
Old 11-25-2012, 03:13 PM   #10 (permalink)
I sifted through the sport tire offerings, not many listed but it seems that the ultra grippy summer ultra high performance tires aren't necessarily all that bad, interesting.
Yokohama Advan A10B for example came in at 9.7 and 10.6 for 2 sizes, and it has a treadwear rating of 160. Michelin Pilot Sport PS2 was 11.1 or so. Kumho Ecsta KH11 10.84. Michelin Pilot Sport Cup 9.23.
The worst one I spotted was a knobbly truck tire at 17 lol.
