Old 09-17-2010, 11:58 PM   #11 (permalink)
I have to start over?
Big inefficient truck - '94 Dodge Ram 2500
90 day: 12.1 mpg (US)
Honda Civic - '84 Honda Civic DX Hatchback
If you ask me about reducing valve train friction, I would say to go with a 2 cycle diesel. How about no valves?
Edit: they have exhaust valves, whoops
Old 09-18-2010, 12:32 AM   #12 (permalink)
The only 2 stroker diesel I'm familiar with (GMC) had valves AND ports and was supercharged.
Old 09-18-2010, 12:33 PM   #13 (permalink)
vtec-e's Avatar
De Yaris - '04 toyota yaris T2
90 day: 69.55 mpg (US)
How about this for reducing valve friction!
Welcome to Coates International Ltd.
Very little if any information on this outside of their website. I'd like to see how they manage to seal the valves without having issues like the rotary engines have with apex seals.
Old 09-18-2010, 04:10 PM   #14 (permalink)
Frank, I stand corrected. I went and looked it up and, low and behold, they do have exhaust valves. Here's an article on it. It doesn't seem like it would be too hard to manufacture one with no exhaust valves (basically it would look just like your weed eater block/head) as long as it had enough boost.
Just imagine making one of these with a super-turbo charger (to get rid of the supercharger load at above idle) and some high performance lightweight pistons/connecting rods. Diesel with a 9k RPM redline!
Old 09-20-2010, 01:30 AM   #15 (permalink)
My dad bought a Willys 6 sedan new in 1931 and even in the 50's people still would ask him if it was a Willys-Knight (with sleeve-valve engine). His had a Continental Red Seal engine IIRC, but many Willys cars had the Knight engine, at extra cost. There was also a Stearns-Knight car and there may have been other makes that used the Knight engine.
The main advantage of these engines was that they were very quiet. Not sure why they would have been so great in aircraft though.
Ray Mac.
Old 09-20-2010, 05:30 PM   #16 (permalink)
That's the rotary valve setup I was mentioning earlier. They've been around for perilously near 20 years that I know of, and have been "just about to enter production" for that whole time.
Last I heard (many years ago) they had significant sealing problems.
-soD
Old 09-20-2010, 07:22 PM   #17 (permalink)
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 Mercedes Benz 300SD
90 day: 23.23 mpg (US)
Gentoo320 - '04 Mercedes C320 4Matic
90 day: 22.44 mpg (US)
The Napier Deltic and Junkers Jumo didn't need valves and were quite efficient
Napier Deltic - Wikipedia, the free encyclopedia
Junkers Jumo 204 - Wikipedia, the free encyclopedia
Old 09-20-2010, 10:34 PM   #18 (permalink)
I've always been fascinated by the opposed piston configuration!
Old 09-21-2010, 01:24 PM   #19 (permalink)
DieselMiser
ConnClark's Avatar
The coolest valveless engine was the Napier Nomad engines.
Napier Nomad - Wikipedia, the free encyclopedia
Part turbine and part diesel engine. The first version even had an after burner.
one also ran at 89psi of boost.
Old 09-21-2010, 01:50 PM   #20 (permalink)
vtec-e's Avatar
Boy did this thread go off on a tangent! Cool link to the napier nomad engine btw.
In relation to the rotating liner though. It's pretty much the only solution to the piston ring drag in an engine that i have seen. Ok, it's more complex but if built properly and by a japaneese company it would be pretty reliable im sure.
There are other losses in an engine too, valves being one of them. The coates system seems to be dead in the water due to sealing issues i suspect.
What are the friction losses like in the desmodromic system used in motorbikes? The lack of valve springs may help?
The diesel fuel pump is also a power hog. Could this be improved upon?
My thinking behind all this is that if a significant amount of fuel is used just turning the engine over, then thats where there should be most of the work done to lower fuel consumption.
Thats not to lessen the importance of good aerodynamics either. It all plays a part.
Ideas anyone?
Heated Fuel bennelson EcoModding Central 81 03-11-2022 12:28 AM
Moving air intake into the engine compartment? pasadena_commut Aerodynamics 5 07-25-2008 04:24 PM
Coasting experiment: engine on VS engine off on a fixed route = 12.9% gain MetroMPG Hypermiling / EcoDriver's Ed 6 02-22-2008 09:38 AM
Basic EcoDriving Techniques and Instrumentation SVOboy Instrumentation 2 11-17-2007 12:38 PM
