Old 09-21-2010, 02:03 PM   #21 (permalink)
I saw nothing in the materials about the "how" of this reducing ring drag. Did I miss it?
Old 09-21-2010, 03:42 PM   #22 (permalink)
no it was pretty vague . My interpretation is the problem is when piston speed reduces speed near TDC , where pressure is the most . When piston speed is fast like at 90deg mark the ring can "glide" over the oil film but near TDC piston is so slow it can't do that and wear kicks in .
I still have hard time thinking this is useful in small auto engines as they already last past rest of car .
On valvetrain I think something along F1 engines with either solenoid or air operated valves . This way you could electronically time them and have greater control .
Old 09-21-2010, 03:50 PM   #23 (permalink)
http://www.youtube.com/user/Ride122609
No reciprocation.
Can de stroke itself an be a flywheel storing energy in its own mass.
No Valves.
No Connecting rods to create side loads (therefore rendering rotating liners irrelevant).
Can be configured as a two stroke, 4 stroke, or a compressor, or IVT in wheel drive.
This is running at close to 2000 RPM on 120 PSI compressed air and weighs over 10 pounds (linked u tube video)
Dry sump pressure lubrication with centrifugal return, that stops providing pressure lubrication when in flywheel mode.
Energy storage in the same mass that is the engine block.
Variable displacement.
Variable compression, as high as 50 to 1 eliminating the need for any supercharging.
Automatic timing advance in compression ignition mode that allows timing to be advanced and compression increased when loads are low, eliminating low BSFC altogether.
Throttleless, excess power is stored in the accelerated mass of the engine block, to be transferred to the powertrain, even in flywheel mode with no fuel consumption.
Atomatic pulse a glide operation when combined with an IVT in wheel drive and a hydraulic accumulator. Constant vehicle speed even when cycling engine on and off with no additional driver imput necessary.
Regeneration efficiencies exceeding 80% wheel to wheel. At least twice as efficient as electric regeneration due to minimal number of necessary steps to accomplish regeneration.
Wheel to accumulator, back to wheel.
Light weight and eliminates all conventional powertrain components from the engine flywheel to the brake calipers and rotors, everything between those two components.
You asked .
regards
Mech
Old 09-21-2010, 03:53 PM   #24 (permalink)
Hmm. They'd have to pin the rings to the piston or the rings might still end up not sliding "rotationally" against the cylinder. Then with pinned rings gook could build up in the ring grooves.
Old 09-21-2010, 04:27 PM   #25 (permalink)
Basjoos Wannabe
ShadeTreeMech's Avatar
The Van - '97 Mercury Villager gs
90 day: 19.8 mpg (US)
Lyle the Kindly Viking - '99 Volvo V70
90 day: 25.82 mpg (US)
The only 2 stroker diesel I'm familiar with (GMC) had valves AND ports and was supercharged.
Ah, but you forgot the venerable Detroit, which had exhaust valves and had forced induction like the GMC variant, which I'm unfamiliar with.
http://en.wikipedia.org/wiki/Detroit_Diesel_Series_71
I suspect emmisions had a bit to do with their lack of popularity in more modern vehicles.
RIP Maxima 1997-2012
Originally Posted by jamesqf View Post
I think you missed the point I was trying to make, which is that it's not rational to do either speed or fuel economy mods for economic reasons. You do it as a form of recreation, for the fun and for the challenge.
Old 09-21-2010, 05:43 PM   #26 (permalink)
Dat would be da same ting.
Old 09-22-2010, 12:16 AM   #27 (permalink)
5speed5's Avatar
TBSS - '08 Chevrolet Trailblazer SS 2WD
90 day: 19.36 mpg (US)
Wife's car - '09 Chevrolet Impala SS
90 day: 22.96 mpg (US)
Big Blue Hippo - '06 Chevrolet HHR 2LT
90 day: 45.99 mpg (US)
No reciprocation.
No Valves.
You asked .
regards
Mech
Very cool! So what are its disadvantages. With all those advantages, if the disadvantages aren't significant, you owe it to society to find a producer for these things.
Daily driver:
Old 09-22-2010, 07:13 AM   #28 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
He owes it to society to put a big disclaimer that none of his % claims have been verified.
Heated Fuel bennelson EcoModding Central 81 03-10-2022 11:28 PM
Moving air intake into the engine compartment? pasadena_commut Aerodynamics 5 07-25-2008 03:24 PM
Coasting experiment: engine on VS engine off on a fixed route = 12.9% gain MetroMPG Hypermiling / EcoDriver's Ed 6 02-22-2008 08:38 AM
Basic EcoDriving Techniques and Instrumentation SVOboy Instrumentation 2 11-17-2007 11:38 AM
