Old 05-28-2010, 05:02 PM   #11 (permalink)
Originally Posted by bhazard View Post
The B8 it a good motor too, just slightly more involved than a B6 swap. Best power per effort swap for our cars though. Shouldnt be too much of a hit to the MPGs either. B8's have the best low end torque of any of the B series I think. And its not too much power to have to swap trannies either. Look out for a protege, should be easier than finding a 323 with a B8.
Though after swapping a B6T and G25MR in my festiva I feel like I could do anything now lol. Its worth it though, and I should be able to manage 40mpg pretty easily. Ive gotten 38.9 and 38.4 my last two tanks, and I still have plenty of room for improvement. Im running without the o2 sensor right now because I have the infamous exhaust manifold crack thats drawing in air over the o2 causing it to run rich (32 mpg). Im also running the stock festiva exhaust which is killing my low end torque with the turbo.
Wouldnt you still have to replace the clutch and axle even with the b6? Yeah alot of members did b6t but one managed a b8 ok.
Can low rpm damage the engine? KiaRio2004 Hypermiling / EcoDriver's Ed 24 10-03-2017 03:16 PM
Efficient Engine Design ??? pgfpro EcoModding Central 110 02-12-2010 01:53 PM
Lower RPM for higher MPG? UltraJosua EcoModding Central 7 07-17-2009 01:56 PM
2000 rpm taco General Efficiency Discussion 37 02-28-2009 05:11 PM
MetroMPG.com mailbag: is lowest RPM really best for max MPG with big displacement? MetroMPG Hypermiling / EcoDriver's Ed 20 01-06-2008 01:00 PM
