Old 10-21-2008, 03:09 PM   #1 (permalink)
EV test pilot
bennelson's Avatar
Electric Cycle - '81 Kawasaki KZ440
90 day: 334.6 mpg (US)
S10 - '95 Chevy S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 Ben Nelson's "Electro-Metro"
90 day: 129.81 mpg (US)
The Wife's Car - Plug-in Prius - '04 Toyota Prius
90 day: 78.16 mpg (US)
S10 Kill Switch
Hey Everyone!
I just installed a kill switch on my '95 S10 4-banger pickup truck.
I shot video of it and will post that sometime for you.
In the meantime, I will go test some engine-off-coasting.
This is using a momentary-on switch on the stick shift to interrupt the fuel injection wire through a relay.
The advantages of this over using the key-off,back-on is that my trip odometer will keep running and my radio will stay on. It has about a 5 second "reboot" time for the radio to come on when you turn the key to "on"!
Now I can save gas without missing my radio program.
I will go for a ride and let you know how it goes!
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
Old 10-22-2008, 11:57 AM   #2 (permalink)
EV test pilot
bennelson's Avatar
S10 - '95 Chevy S10
Yesterday, I installed a kill switch in the truck.
Today, the CHECK ENGINE LIGHT no longer comes on, but I am having another problem instead!
I have no power when I put the gas pedal down farther than about half-way!
This gives me terrible acceleration, and I can barely make freeway speed. I can slowly accelerate if I am level or slightly downhill.
Uphill, things start slowing down because I can't push the gas pedal down far enough before it starts losing power!
Also, if I rev the engine up real high, when in neutral with the parking brake on, it sort of shutters and snorts.
Is this a "fuel-rich" problem? When I give it gas, it's getting too much gas, and I lose power?
When I installed the kill switch, I cut the wire to the fuel injectors, and added a momentary off relay in-line to it to turn off the engine.
I put a jumper back in so that that wire is connected directly again (no relay) and am still having the same problem.
Please don't tell me that that's a special wire that has very particular resistance that effects the injectors or something like that!!!!!
What could be wrong with the truck?!?!?!
I have no idea if the problem is from the kill-switch or completely un-related!
Thanks in advance!
My YouTube Videos
Old 10-23-2008, 08:16 PM   #3 (permalink)
Boxhead
whokilledthejams's Avatar
Boxy Brown - '04 Scion xB
90 day: 35.48 mpg (US)
Send a message via AIM to whokilledthejams
Your catalytic converter might have given up the ghost. The 95 Sonoma (essentially an identical truck to yours) I had ages ago acted just like that when the cat got backed up.
I drilled holes in it so that it would run until I could get it fixed.
Odds are, it's the 2nd cat that truck's had in it's lifetime, maybe even the original.
Kill switch how-to bbjsw10 DIY / How-to 195 05-20-2014 01:27 PM
Kill switch for 88-95 Honda Civic/CRX/DelSol AndrewJ DIY / How-to 40 06-18-2012 03:13 AM
Fancy kill switch wiring extragoode EcoModding Central 2 10-15-2008 01:14 AM
help W/ Remote Kill Switch Idea 93hatchDX DIY / How-to 21 07-31-2008 03:46 PM
Winter mod - heater blower integrated with engine kill switch MetroMPG EcoModding Central 3 12-31-2007 10:31 PM
