Old 08-24-2013, 10:13 AM   #11 (permalink)
SilverVan - '13 Dodge Grand Caravan SXT+
Team Dodge
90 day: 17.6 mpg (US)
Originally Posted by HyperMileQC View Post
-Engine loading (LOD)
-Throttle position sensor (TPS)
-Water temperature (°cWT)
-12v Battery voltage (VLT) / Engine RPM / Intake air temperature (°cIA)
I wish TPS and LOD had decimals...
You probably could get them to display decimals via xgauge, I know someone did on a different forum with these value :
ISO/VPW
Throttle Position (XX.X%)
TXD: 686AF10111
RXF: 044185110000
RXD: 2808
MTH: 00C800330000
NAM: TP
It steps in 0.4% increment due to hardware limitation (255 discrete steps)
Maybe you could get it to work!
Old 08-24-2013, 02:24 PM   #12 (permalink)
HyperMileQC's Avatar
Trollinsight (Retired) - '00 Honda Insight
Gen-1 Insights
90 day: 68.06 mpg (US)
Redsight - '01 Honda Insight
Gen-1 Insights
Carole - '05 Toyota Corolla Xrs
Brise-Fer - '05 Toyota Echo
Send a message via MSN to HyperMileQC
the OBD-II protocol of my Insight is CANLF. I don't think ISO or VPW xGauges will work, thanks anyway for this good info, this could be usefull for people with this protocol .
Trollinsight Modding Thread
2000 Honda Insight MT Silverstone Metallic #95 (CAN) 131K mi. 81.7 Lmpg
Best Tank : 100.06 MPG (US) | 120.2 MPG (Imp) | 2.35 L/100Km | 42.54 Km/L
Best commute : 130.8 MPG (US) | 157.1 MPG (Imp) | 1.8 L/100Km | 54.84 Km/L
Best Trip : 111.8 MPG (US) | 134.3 MPG (Imp) | 2.1 L/100Km | 47.53 Km/L
Old 08-26-2013, 09:46 PM   #13 (permalink)
Team Dodge
I found how to make some gauges with decimals, they work in my Caravan, which is CANSF, so I'm not sure they'll work with CANLF, but I'm sure someone can figure it out ;-)
Fuel level w/ decimals
TXD: 07DF012F
RXF: 0441452F0000
RXD: 2808
MTH: 271000FF0000
NAM: _F%
Throttle position w/ decimals
TXD: 07DF0111
RXF: 044145110000
RXD: 2808
MTH: 271000FF0000
NAM: Tps
Relative throttle w/ decimals
TXD: 07DF0145
RXF: 044145450000
RXD: 2808
MTH: 006400010000
NAM: Rth
Engine load w/ decimals
TXD: 07DF0104
RXF: 044145040000
RXD: 2808
MTH: 006400010000
NAM: Lod
Accelerator position w/ decimals
TXD: 07DF0149
RXF: 044145490000
RXD: 2808
MTH: 271000FF0000
NAM: Acc
Old 09-14-2013, 12:43 AM   #14 (permalink)
101Volts's Avatar
Woody - '90 Mercury Grand Marquis Wagon LS
Last 3: 19.57 mpg (US)
Brick - '99 Chevrolet K2500 Suburban LS
Last 3: 12.94 mpg (US)
M. C. - '01 Chevrolet Impala Base
90 day: 18.73 mpg (US)
R. J. - '05 Ford Explorer 4wd
90 day: 16.66 mpg (US)
Originally Posted by 101Volts View Post
Top Left: Instant MPG Top Right: GPH
Bottom Left: AVG MPG Bottom Right: IGN/LOD
That's how I have it today. I recently started using the GPH gauge.
*Note - IGn/LOD meaning that I might have it at one or the other.
I've used other gauge combinations now (On the right, Keeping what was on the left) and cycled through some gauges at red lights and other points of a trip to see how the van worked and one gauge reacted in relation to another. I recommend doing this, To learn.
For example, I learned that the IGN went way down and hovered between 9-14 when stopped in neutral at a red light but the MAP went down a bit too along with GPH (Though it was comparably the same in drive some times) and HPR also did go down when I tried it.
Also, I started using TPS (Throttle Position Sensor) Lately which has been helpful. In the van it is set to 16 when I'm not holding it down; I'm not sure what it would be held down all the way.
Old 09-17-2013, 07:02 PM   #15 (permalink)
101Volts's Avatar
As it was 2013-September-17:
Top Left: TPS Top Right: MPH
Low Left: MPG Low Right: HPR
(MPG = Instant MPG)
Feel free to try other configurations, I was going with Instant MPG and Average a lot but I can learn in this way too.
Old 09-17-2013, 07:43 PM   #16 (permalink)
UFO
UFO's Avatar
Colorado - '17 Chevrolet Colorado 4x4 LT
90 day: 23.07 mpg (US)
Top Left: Tank MPG Top Right: Water Temp
Low Left: GPH Low Right: Boost
GPH is fuel consumption rate in gallons per hour. My TDI has no cluster gauges, so I had to program coolant temperature and boost as Xgauges.
I'm not coasting, I'm shifting slowly.
Old 09-17-2013, 09:13 PM   #17 (permalink)
Valerie - '03 Honda Civic DX
90 day: 55.79 mpg (US)
UL: Instant MPG UR: AVG MPG
LL: RPM LR: MPH
My stock gauges suck so I use this for RPM (I don't have a tach) and MPG. Otherwise, I'd have those at coolant temp and LOD
Old 09-18-2013, 02:15 PM   #18 (permalink)
...beats walking...
[.rpm. ][.mph.]
[ mpg* ][mpg**]
* = MPG avg
** = MPG instantaneous
Old 09-18-2013, 07:19 PM   #19 (permalink)
101Volts's Avatar
As it is now:
(MPG = Instant MPG)
Feel free to try other configurations, I was going with Instant MPG and Average a lot but I can learn more this way too.
I changed the bottom right one to fWT today. Perhaps I'll add a partial duct tape grille block soon.
Old 09-19-2013, 12:24 PM   #20 (permalink)
My scanguage settings
I have a 2000 Silverado, 2wd, 4.8 L V8, and a ScanguageII, couple years old, has 4 spots. Here's what I watch on it, first 3 spots are always the same:
Top left, MPH because it's closer to my line of sight than the speedometer.
Top right, avg MPG generally 21 at 70, 23 at 60.
Bottom right, instant MPG, try to keep this higher than the avg. MPG
Bottom left, I cycle through based on my mood.
Here's what I run in the bottom left and why:
LOD most common, I use the loading % to even out hills, trying to keep just a little above the flat number while going up hills on the highway. It's almost always below 20.
TPS I use throttle position if I want to monitor the cruise control or the Mrs. Sometimes I use it when towing to see how deep I'm going. Usually under 20%, 25 or even 30 if the horses are being damned. Seems closely correlated to LOD.
HPR Horsepower is fun to watch, especially when towing. Not sure if it's meaningful or accurate. Only seen above 100 towing. Also correlated to TPS and LOD.
VLT I had a weak battery, so I watched this for a while to be sure it was the battery and not the alternator. There's a guage on the dash too, but I liked the number
Intake Air Temp. I watch this in the winter, to know what a tough ass I am, or the number of minutes to frostbite. Lowest I've seen is -38
Coolant Temp. I like to compare this to air temp in the winter, to see how much heat I am retaining. Dash guage doesn't register below 100. This was important with the weak battery and the -38, I'd try to keep this number above -20 through the night so it'd start in the morning.
Open loop/Closed Loop. I watched this until I realized the 9999 instant mpg says the same thing. 2nd or 3rd gear will allow <40mph open loop on a downhill, fyi.
GPH This is just depressing, rarely watch it, I just avoid idling.
MAP This is not meaningful for me, because I am an ignoramous.
I think there are others, but I can't think of them, and I don't watch them very much. I never tried the miles to empty. I use the trip odometer for that anyway.
Maybe others could expond on what MAP and other things mean and why you would watch them.
