Old 01-06-2013, 07:58 AM   #1 (permalink)
Wiki Mod
Weather Spotter's Avatar
Max - '14 Ford C-Max SEL
Measuring engine on vs car on with engine off
I have been thinking that I'd like to have a way of measuring engine hours. Because it odometers not a real good reading when I spend a large fraction of my time engine off coasting.
It would be useful to be able to track hours not miles so I know how much wear is on the engine and its components. It would also make a good number to track how much pulse and glide is on each tank.
I was thinking of measuring car on hours and engine on (rpm>0). I have a very limited idea on how to do this. The car on hour meter is straight forward, hooks to a power source that is only on with the car, say the radio wire that comes on with the car? The engine one is past where I can figure it out. Any help?
Old 01-06-2013, 09:10 AM   #2 (permalink)
Eco-ventor
jakobnev's Avatar
Princess - '92 Mazda MX-3 GS
House of Tudor
Team Mazda
90 day: 53.54 mpg (US)
Shirubāarō (*´ω`*) - '05 Toyota Prius Executive
90 day: 54.88 mpg (US)
Blue Thunder - '20 Hyundai IONIQ Trend PHEV
Plug-in Hybrids
90 day: 80.56 mpg (US)
Send a message via MSN to jakobnev
Ignition being on and the oil/alternator warning light being off, should mean that the engine is running.
Old 01-06-2013, 10:04 AM   #3 (permalink)
Adventurist!
CLaero - '97 Acura CL Premium
90 day: 34.59 mpg (US)
CR-v - '03 Honda CR-V EX
90 day: 26.52 mpg (US)
Crank/Cam angle Sensor.
'97 Acura CL 2.2L 5spd
'03 Honda CR-V 2.4L EX 4wd Auto
Old 01-07-2013, 06:01 PM   #4 (permalink)
Wiki Mod
where would I find these wires? Anyone hooked up hour gauges? I have never done it before.
Old 01-08-2013, 05:33 AM   #5 (permalink)
AndrzejM's Avatar
Berta - '97 BMW 318 tds Compact
90 day: 62.03 mpg (US)
Charlie - '07 Citroen C4 Grand Picasso Exclusive
90 day: 37.58 mpg (US)
Corsa - '05 Opel Corsa C
90 day: 53.22 mpg (US)
Mruczek - '03 Audi A2
90 day: 60.61 mpg (US)
Hi,
You may try some of those mentioned here: Hour Meters, Gauges
And here you can find a discussion regarding the issue: Installing Hour Meter - Source of +12V when engine is running? - Insight Central: Honda Insight Forum
It's quite simple you need two hour meters one hooked up to the ignition to measure whoe time of car running and second one hooked up to oil pressure switch to measure engine's running time. Then you have everything that you want.
Gerhard Plattner: "The best attitude is to consider fuel saving a kind of sport. Everybody who has enough money for a strong car, can drive fast and hit the pedal. But saving fuel requires concentration, self-control and cleverness. It's a challenge with the nice effect of saving you money that you can use for other more important things."
The Following User Says Thank You to AndrzejM For This Useful Post:
Weather Spotter (01-08-2013)
