Old 10-06-2010, 06:30 PM   #11 (permalink)
Wiki Mod
Weather Spotter's Avatar
Max - '14 Ford C-Max SEL
Does the port work at the dealership or with an auto part store's scanner?
of not then it is on your end. If it works there then call up the scangauge people And explain what is going on. If they claim the SG will work with your car they need to prove that it works.
Old 10-06-2010, 06:42 PM   #12 (permalink)
Brian's Golf - '00 Volkswagen Golf
90 day: 38.01 mpg (US)
The car worked when hooked up to a scanner at a local garage, not at a VW dealership. I never thought it would make a difference but You could be right, might be worth looking into. It's weird, I've spoken to 3 different people from Scanguage and they all say it should work with the vehicle. Very suprising it doesn't.
Old 10-06-2010, 06:47 PM   #13 (permalink)
Wiki Mod
So it did not work at the dealership? Or you have not tried it there?
Old 10-06-2010, 06:53 PM   #14 (permalink)
No, I have not tried it at the dealership.
Old 10-06-2010, 06:55 PM   #15 (permalink)
Wiki Mod
I would try it there and see if it works. That will put the ball back onto scangauge's court.
Old 10-06-2010, 07:01 PM   #16 (permalink)
Smile
Yeah it's worth a shot I'll bring it in over the next day or two, thanks very much for the advice!
Old 10-06-2010, 07:06 PM   #17 (permalink)
Wiki Mod
It is worth a try. It will show that you are not making it up (l do not claim you are).
If scangauge said it should work and it will not, they should make it work.
Old 10-06-2010, 07:12 PM   #18 (permalink)
Exactly, You are correct , if theres nothing wrong with the car, then it's false advertising essentially.
Old 10-07-2010, 04:39 AM   #19 (permalink)
The PRC.
If you don't get it to work maybe try a TurboGauge which is supposed to be a knock off of a knock off of the SG2. Not cheaper now SG2s come in from Greece but maybe worth a shot.
Old 10-07-2010, 12:15 PM   #20 (permalink)
Thanks for the suggestion, I was looking at a Turboguage they are about £100, but if it's a knockoff of the SC2 using similar software, maybe it won't work either? I was also looking at an Ultraguage because it is not linked to Scanguage at all but I'm still worried it might not work either.
Newbie! VW Golf TDi kammback ideas? theoteacher DIY / How-to 2 06-15-2011 08:34 PM
Big bumper or small? (VW Golf Mk2) G2TDI Aerodynamics 74 03-28-2011 02:29 PM
VW Golf mods matthew EcoModding Central 6 09-30-2010 12:42 PM
News: VW to unveil 70 mpg (US) Golf diesel hybrid MetroMPG Hybrids 27 06-29-2010 07:50 AM
Biodiesel UK test VW Golf - MPG results pending sallen Fossil Fuel Free 5 02-20-2010 11:09 AM
