01-12-2011, 04:15 PM
#341 (permalink)
Well, yes and no -- the first cameras were great, but one of them started cutting out randomly, so I replaced it. The new camera shows almost all white on the screen when it is completely dark -- so that one is too bright at night. The other one, though is fine, and you get much less glare than with optical mirrors, from headlights and such.
01-13-2011, 12:19 PM
#342 (permalink)
So the combination of the "right" camera and screen works just fine at night? I am sure you already posted this before but mind posting again which camera & screen you'd recommend now after "trial & error"?
01-13-2011, 02:07 PM
#343 (permalink)
Yes, they are fine at night if the camera doesn't "open up" too much. In fact, the lack of blinding glare from headlights behind you is a big advantage. They have infrared LED's that light things within 15' or so; without having any visible light.
I actually have the same camera (more or less); the better and the worse ones are ostensibly the same. The one that is too white at night (because it's 'F-stop' circuit lets in too much light?) also has some green lines superimposed on the image (to try and assist with depth perception); but I don't think that is the cause for the problem.
All the cameras are challenged at the other end of the light strength: when in direct sunshine, they get overwhelmed -- the 'F-stop' stepping needs to be able to work in direct sunshine. Also, the screens I have get darker as they heat up -- they produce a fair amount of heat from the backlight and so in bright sunshine, they are not easy to use.
The video mirrors are best in situations when optical mirrors are weakest: at dusk and in the rain.
So, the bottom line is, I still use a small optical mirror on the driver's side, for when the car isn't running (like when I have parked in a parallel space, and need to see traffic to open the door), or when the screen is hard to see because it is in direct sunshine and/or the camera is washing out the image.
I've been running these video mirrors for over 2 years now, and they work, but I certainly see the need for various improvements. Another one that I have not mentioned in this post is the need to optically correct for the barrel distortion that these very wide angle cameras have.
01-13-2011, 03:39 PM
#344 (permalink)
...so as a conclusion one could even question the benefits vs the disadvantages?
Has anyone ever done any experimenting with prisms?
Prism (optics) - Wikipedia, the free encyclopedia
Somehow my head wants to think there should be some such solution that should work fairly well, one could even get a fairly large reflection area with minimal external area (outside the car), no?  anyone?
01-13-2011, 03:49 PM
#345 (permalink)
01-13-2011, 04:02 PM
#346 (permalink)
On balance, they help with my fuel mileage, and they work well enough to keep me driving safely. I will probably put some on my CarBEN EV, though I will also try to do some sort of inside optical mirrors -- the tapered shape could help these be a little more useful.
01-13-2011, 07:48 PM
#347 (permalink)
Do you have numbers as to how much you save without stock mirrors? What's CarBen?
01-13-2011, 10:09 PM
#348 (permalink)
I don't have hard numbers, but my memory is that my high mileages went from 48-49 to 53+ and my average went from ~46-47 to over 50MPG.
CarBEN EV is my open source design for a super efficient 5 seat electric car:
http://ecomodder.com/forum/showthrea...ter-11969.html
01-14-2011, 01:21 AM
#349 (permalink)
Have you played with the idea of putting the cameras in some non conventional location? Like this for instance:
Side view cameras now available on BMW 7 Series – ultraGADGET
Looks like a great project!
Personally about electrical cars I have a big hangup for now on DIY solutions for now. Cause on engine swaps (like what I am about to do) it's still a car engine into another car. Yet on electrical setups there's plenty of parts that are non-automotive being used
01-14-2011, 01:34 AM
#350 (permalink)
