Old 07-10-2008, 12:01 AM   #11 (permalink)
I'm going to concur with jonr at post #8. When I got my ScanGauge I found I was driving too softly. Not only does it increase the likelihood of incoming fire from the people behind you, but it keeps you in low gear longer. I don't floor it (my gas peddle has never known the floor), but I move out aggressively to get through the first two gears. I can watch the instantaneous MPG climb with each gear. Even going up hill, I push it to get into third gear. When you average the longer distance at low MPG, it drags down the total.
PS: FWT FIA to monitor new Hot Air Inlet
TPS to control foot
MPG to see how the foot is doing
Last edited by mwpiper; 07-10-2008 at 12:04 AM.. Reason: forgot to answer the question
Old 07-11-2008, 06:02 PM   #12 (permalink)
Mr. Blue Tape
azraelswrd's Avatar
AzxA - '06 Scion xA
90 day: 42.72 mpg (US)
update:
MPG
AFC (Avg FE for Current trip)
FWT
TPS
my MPH and RPMs are fairly consistent from the SGII and my instrument cluster
My 5 pillars of fuel efficiency:
  • driving style
  • aerodynamics
  • tires
  • weight reduction
  • engine maintenance
Old 07-11-2008, 06:18 PM   #13 (permalink)
Lurking EcoModder
Q1kS2k - '02 Honda S2000
F150 E - '13 FORD F150 XLT
WHITE CIVIC - '07 HONDA CIVIC LX
Fwt Fia
Lph Lhk
Old 07-18-2008, 09:14 AM   #14 (permalink)
It would be nice if it allowed you to load in a BSFC chart so that it could display BSFC.
Or use an accelerometer or GPS input to derive it (with long term averaging to account for hills).
Old 07-18-2008, 09:25 AM   #15 (permalink)
rjacob's Avatar
2017 Honda Civic LX - '17 Honda Civic LX
90 day: 39.92 mpg (US)
MPH, MPG, TPS, and either water temp or GPH.
GreenCarMPG.com
Old 08-01-2008, 02:47 PM   #16 (permalink)
97Cavalier
Yaris - '09 Toyota Yaris Base
90 day: 40.51 mpg (US)
For myself I use:
RPM - MPH
MPG - TPS
With my 4-spd auto trans I tend to keep the TPS <= 20 or 25 depending on how much traffic is behind me and on the highway I've found that my '97 Cavalier gets the following mpg's.
Without A/C: TPS of 10-12 will hold a steady speed on the flats and at 60mph I can usually average between 45mpg - 50mpg.
With A/C: TPS of 15-18 will hold a steady speed on the flats and at 60mph I can usually average between 31mpg - 35mpg.
Jeff
Old 08-01-2008, 05:58 PM   #17 (permalink)
Mr. Blue Tape
azraelswrd's Avatar
AzxA - '06 Scion xA
I try to keep my TPS around +4 and +6 above idle for FE while trying to stay between 45 and 55mph.
  • driving style
  • aerodynamics
  • tires
  • weight reduction
Old 08-01-2008, 09:32 PM   #18 (permalink)
PA32R's Avatar
LR3 - '06 Land Rover LR3 HSE
Originally Posted by jonr View Post
A really light foot with slow acceleration hurts FE*. People would be better off with a BSFC readout during acceleration. Preferably one that would display negative numbers when you hit the brakes.
* you get good instant FE numbers, but it also takes longer to get up to speed. So it is misleading.
I don't know about that. I don't have an engine map for my vehicle but I assume it looks generally like the ones I've seen. It's clear that ultra slow acceleration doesn't utilize the most efficient areas of the map, but there's another factor.
Looking at the vehicle as the system boundary and outside as the environment (that is, ignoring the rotating masses in the drivetrain, etc.), fuel is used to do two things: overcome resistance (rolling, aerodynamic drag) and to add kinetic energy during acceleration (assuming level ground). If I accelerate slowly, that portion of fuel that goes to add a given amount of kinetic energy is burned over a greater distance - the calculations are quite easy and I can show it if anybody wants. But if I accelerate at half the rate, I'll go twice as far to get up to any given speed and that portion of the chemical potential energy that is converted to added kinetic energy is used more efficiently in that sense.
Combining this with bsfc on the engine map turns out to be a fairly thorny mathematical problem, though I'm working on it using a "generically" shaped engine map with a few tweaks to accurately represent those few spots I know about on my vehicle. Maybe somebody here has modelled this? It's a problem in numerical integration.
Sorry to hijack the thread.
Old 08-01-2008, 11:06 PM   #19 (permalink)
MKL
Mola mola - '08 Honda fit basic
90 day: 40.57 mpg (US)
RPM MPH
MPG Lod
Old 08-01-2008, 11:12 PM   #20 (permalink)
Hi,
I used XGauge to map the average MPG (normally in the Trip selections) to be available in the Gauge options:
AVG TPS
MPG fWT
SGII Not quite right dremd Instrumentation 37 09-26-2008 12:33 PM
SGII Read out trikkonceptz Instrumentation 1 05-16-2008 05:25 PM
any way to get SGII to show which gear I'm in? blackjackel Instrumentation 15 05-15-2008 06:29 PM
SGII + ICE OFF = .003 cpm? Chris D. Instrumentation 6 05-09-2008 02:00 AM
just got my SGII (ScanGauge II) few questions for the collective.. Chris D. Instrumentation 27 04-22-2008 07:38 PM
