Old 02-16-2009, 07:08 PM   #1 (permalink)
EV test pilot
bennelson's Avatar
Electric Cycle - '81 Kawasaki KZ440
90 day: 334.6 mpg (US)
S10 - '95 Chevy S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 Ben Nelson's "Electro-Metro"
90 day: 129.81 mpg (US)
The Wife's Car - Plug-in Prius - '04 Toyota Prius
90 day: 78.16 mpg (US)
Aeromod the Electro-Metro
Hey Guys,
Darin pointed out to me that if I start getting the Electro-Metro up to decent speeds, it's the WIND-RESISTANCE that's going to kill my watt-hours-per-mile!
With that in mind, throw your suggestions my way for AERODYNAMIC improvements to my modest EV.
This is a bit premature/hopeful, but I DO plan to crank my voltage to over 100, and with it, gain unprecidented speed!
The car is already lowered (due to battery weight!) so that's taken care of already. The passenger mirror is also removed.
I have always loved the baby-moon/pizza-pan hub caps, so I plan on those eventually. Anyone have 13" pizza pans?
I also liked MetroMPG's Firefly rear wheel skirts - very classy looking.
I am still trying to do all this on the cheap, and have PLENTY of other things to do on the car as well, but I thought I would just throw it out there!
-Ben
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
Old 02-16-2009, 07:12 PM   #2 (permalink)
90 day: 51.82 mpg (US)
One of the advantages of an EV is you can fully seal the grille/motor compartment and implement a full belly pan, because you don't have to deal with hot exhaust components. Maybe a very small allowance for a motor cooling intake duct.
After doing that, wheel discs, and the rear skirts (the pretty easy stuff), you need to focus on the back of the car. That's where the action is.
That Kammback is worth about a 5% improvement in fuel economy (range) at 55 mph, based on incomplete testing (only A-B comparison, not A-B-A).
http://ecomodder.com/forum/showthrea...sion-3518.html
Old 02-16-2009, 07:14 PM   #3 (permalink)
OH!
And since you're giving up the rear seat for battery space anyway...
Hey - this can be done cheaply. You didn't say easily.
http://ecomodder.com/forum/showthrea...ropped-90.html
Old 02-16-2009, 07:18 PM   #4 (permalink)
Thinking about this: the cool thing about improving aero on an EV is that the range benefit will be greater than the same mod on a gasoline ICE vehicle.
Reducing power requirement for a gasoline car reduces fuel consumption, but it also moves the engine further from the best BSFC island (assuming cruising conditions).
So let's say a particular mod returns a 5% range increase for a gas car. It's going to be greater than that for your EV because you're not penalized for reducing pressure on the go pedal, the way you are with the gas engine. In fact the EV gets an additional bonus: not only do you reduce power requirement for a given speed, but by reducing current draw you also reduce Peukert losses which increases range even further.
So a 5% fuel economy gain in a gas car is definitely going to be a greater than a 5% gain on an EV.
Old 02-16-2009, 07:35 PM   #5 (permalink)
Electro-Metro
I'd follow Darin's lead and if you can build the stomach for it later,do the full Monty, mimicing basjoos Aero-Civic.------------------- Down the road,as your sanity ebbs,consider a fully integrated complete boat-tail trailer with gap-fillers/tow-behind generator set for "hybrid" long-distance electric travel.Alan Cocconi and the Volvo team drove their EVs from Los Angeles to the Phoenix Solar-500 this way,except they didn't get the part about the trailer aerodynamics.You could make history!
Old 02-16-2009, 07:40 PM   #6 (permalink)
WonderWagon - '94 Ford Escort LX
Last 3: 51.52 mpg (US)
DaBluOne - '99 Ford Escort SE
90 day: 48.97 mpg (US)
DaRedOne - '99 Ford Escort ZX2 Hot
Hope that's intended as humor.
First the overloaded springs take on a permanent sag.
Then sooner or later (depending on how overloaded) they break.
Old 02-16-2009, 11:01 PM   #7 (permalink)
EV test pilot
bennelson's Avatar
S10 - '95 Chevy S10
I am only half-joking about the lowering. The car already was a low design, but it IS sitting low from the batteries. I do need to modify the suspension.
I am not finding any truely useful information anywhere about boosting the rear suspension.
It looks like the easiest thing to do about it is air-bags inside the rear springs.
My YouTube Videos
Old 02-17-2009, 12:12 AM   #8 (permalink)
Bicycle Bob's Avatar
Last 3: 42.35 mpg (US)
Maybe if you poke around a junkyard you can find some helper springs, or something that can be made to fit and has a little bit thicker wire in the coil.
Given that you don't have to worry about hot exhaust parts, you could do a very smooth belly pan, which is better than lowering and reducing underflow. The smooth, sealed front end sounds great, too.
Old 02-17-2009, 02:47 AM   #9 (permalink)
Piaggio Fly 150 - '10 Piaggio Fly 150
90 day: 64.8 mpg (US)
The other great thing about aero-modding an EV is that you always have a precise measure of the exact power requirement to maintain that speed i.e. volts x amps. No more complex loop fuel measurements or expensive instantaneous fuel use displays... just check the amp-meter and note the difference... Should make testing a lot more conclusive
Check out my Green Cars Blog and the DIY electric car Wiki. Enjoy!
Old 02-17-2009, 08:57 AM   #10 (permalink)
I'd definitely start with a full frontal block. Seal that puppy up. And you just got that nice roll of coroplast!
Geo Metro convertible / Kubota diesel engine conversion (driving!) kimer6 EcoModding Central 118 07-01-2013 04:21 PM
Why I'm Choosing a Civic Over a Metro Wayneburg General Efficiency Discussion 43 03-02-2011 05:11 PM
Planning Project Eco-Z seanof30306 EcoModding Central 20 08-24-2009 10:00 PM
Metro Hoarding 101 - also: Metro pickup trucks! Cowspots Introductions 28 04-14-2008 07:26 PM
Radical Metro Aero Mods? Coyote X Aerodynamics 8 01-01-2008 04:05 PM
