09-09-2009, 05:58 PM
#1 (permalink )
eco....something or other
How much HP and Torque can a TCC handle???
common sense tells me that they would have to be pretty durable to handle what they do for as long as they do. But I still wonder why they unlock at 90% load, is it because the car knows you want more power so it lets the rpm go up?
how much gas can i give it without damaging it in lower gears? part of the reason i ask is because cars don't generate much power at low cruising rpms. Is that why TCC don't lock up all the time in 2nd through...?
1991 F-250:
4.9L, Mazda 5 speed, 4.10 10.25" rear
09-09-2009, 06:15 PM
#2 (permalink )
needs more cowbell
A torque converter is able to multiply torque when there is a significant difference between input and output speeds.
Torque converter - Wikipedia, the free encyclopedia
at %90 load, maybe they think you want more torque (not always true)?
09-09-2009, 06:51 PM
#3 (permalink )
Camryaro - '92 Toyota Camry LE V6
90 day:
31.12 mpg (US)
Red - '00 Honda Insight
Prius - '05 Toyota Prius
3 - '18 Tesla Model 3
90 day:
152.47 mpg (US)
I think the OP is asking about the lock-up clutch.
09-09-2009, 06:55 PM
#4 (permalink )
needs more cowbell
if you unlock the torque converter, it can multiply torque, yes, inefficiently.
09-09-2009, 07:11 PM
#5 (permalink )
42.
09-10-2009, 12:02 AM
#6 (permalink )
42 what? nt
1991 F-250:
09-10-2009, 12:26 AM
#7 (permalink )
needs more cowbell
It is the answer to everything.
http://ecomodder.com/forum/showthrea...und-10073.html
Click on the movie link, it should explain everything
09-10-2009, 12:34 AM
#8 (permalink )
I wonder how much wood can a woodchuck chuck-
if a woodchuck could chuck wood?
Is it 42?
09-10-2009, 12:35 AM
#9 (permalink )
must be
1991 F-250:
09-10-2009, 12:40 AM
#10 (permalink )
Good. Now I will be able to get a good night's sleep.
Thread
Thread Starter
Forum
Replies
Last Post
Minimum HP requirement
superchow
General Efficiency Discussion
16
08-26-2009 10:29 PM
