Old 05-04-2008, 10:34 AM   #11 (permalink)
The Civic - '00 Honda Civic DX
90 day: 37.05 mpg (US)
Just getting the big hatch glass on my CRX tinted very dark helped cool it down enough that I never bothered with the side windows.
Old 05-04-2008, 11:35 PM   #12 (permalink)
Giant Moving Eco-Wall
DifferentPointofView's Avatar
The Jeep! - '95 Jeep Grand Cherokee ZJ Laredo
90 day: 23.75 mpg (US)
The Caliber - '07 Dodge Caliber R/T
90 day: 30.6 mpg (US)
The 'Scort - '98 Ford Escort LX
I've seen coupons for a tint job at 99 bucks, but that's around here at the local shops and dealerships, I don't know about there.
Transitions lenses!! thats what they're called? Now I wonder if you can get them for your car... :/
I found this while looking up the name of those lenses
http://www.whynot.net/ideas/2708
Yea.. I drive a Jeep and I'm on a fuel economy site, but you just wouldn't understand... "It's a Jeep thing!" *Jeep Wave*
Did I Use Too Many Abbreviations? Here's The Abbreviations List
Old 05-05-2008, 12:08 AM   #13 (permalink)
pontiac trans am - '00 pontiac firebird trans am
jeep 1 - '02 jeep wrangler
90 day: 16.76 mpg (US)
jeep 2 - '07 jeep wrangler x
90 day: 19.39 mpg (US)
Toyota - '09 Toyota Corolla lx
DPoV, just reading one of the comments about the glass made me laugh, the person must not realize that transitional lenses have a coating and that its not the glass that makes it tint. the only problem i had with my lenses when i had them was that about a year after i got them the tint didnt get noticeably darker and the lenses developed a tint even when there wasnt much light.
thats not a problem with glasses because you are supposed to replace them yearly but it could be an issue on your car...
Old 05-05-2008, 01:17 AM   #14 (permalink)
IHATEGAS
corvette2000's Avatar
I recently tinted my windows myself on my 96 Aspire and man I got frustrated fast with my back window I gave up because there were these long bubble fingers I could not flatten out I used a hairdryer to shrink the tint but did not work so I tinted the back side windows and front windows the back side window came out ok but the front I made some mistakes but will do for now. I did make some calls around and for a 2 door Aspire it was going to cost like $150-120 but I did mine for $22. for the front and back side window.
Old 05-05-2008, 01:34 AM   #15 (permalink)
Grrr :-)
Nerys's Avatar
Cherokee - '88 Jeep Cherokee
90 day: 19.44 mpg (US)
Ryo-Ohki - '94 Geo Metro Xfi
90 day: 50.15 mpg (US)
Vger 2 - '00 Plymouth Grand Voyager SE
Ninja - '89 Geo Tracker
90 day: 30.27 mpg (US)
Hmmm that reminds me I must tint my jeep windows before I start driving her again. I burn VERY easily. Having my arm on the door sill for the 90minute drive to work is enough to give me sunburn. All my current vehicles have tint from the factory on all door windows and I have not been burned. Where do I get this UV only stuff from?
Old 05-05-2008, 02:12 AM   #16 (permalink)
Liberti
LostCause's Avatar
Thunderbird - '96 Ford Thunderbird
90 day: 27.75 mpg (US)
The glass should be blocking out almost 100% of the UV radiation from the sun. You will not get burned if the windows are up. Richard Feynman watched the whole trinity test through the window of a truck without any other protection.
I'd imagine tint would only really help if you have a dark interior, but I suppose it won't hurt. I would go one level over legal on the sides and the next level above that on the rear. If you see a cop, roll down your windows.
The transitions lenses sounds like a creative idea, but I wonder what it would cost (if the coating was available)? The welder's helmet idea wouldn't work over so well simply because it requires a current to stay clear. The tint comes from a LCD panel, I believe.
Unless you drive for long periods of time, I'd rather invest in a sunshade or a white car cover for the times you are parked outside.
- LostCause
Old 05-05-2008, 02:20 AM   #17 (permalink)
Grrr :-)
Nerys's Avatar
Well then my 88 Cherokee broke the rules. it definately does not block UV or at least no where near enough to stop me from burning. :-) I know I have had the sunburn to show for it. I do drive for long period. 90 minutes each way 4 days a week at least and many trips upwards of 20+ hours sometimes :-)
Old 05-05-2008, 03:03 AM   #18 (permalink)
Liberti
LostCause's Avatar
Reading up on UV light at wikipedia, it looks like "it depends."
Normal window glass will let in 90% of light above 350nm and reflect 90% of light below 300nm. UVA, which is implicated in long term, deeper skin tissue damage, passes through relatively easily. UVB, which is the culprit of sunburns, has a wavelength of 320nm and below.
Pure glass (SiO2) is almost perfectly opaque to both types of UV light, I believe. Some synthetic, specialty "fused quartz" (SiO2, still) are completely transparent to UV light. UV transparency is also dependent on thickness.
Overall, you shouldn't get a sunburn in your car unless you are really sensitive to UV light and/or are exposed to it for a long period of time. Nice to learn that it isn't perfectly protective, though. Richard Feynman didn't go blind or get cataracts...maybe he was lucky (or was looking through pure glass).
- LostCause
Old 05-05-2008, 03:46 AM   #19 (permalink)
Nden's Avatar
Send a message via MSN to Nden Send a message via Yahoo to Nden
go with medium tint on the back 3 windows, so u can still see decently out the back. i've got dark on my back 3 currently,but will have it changed to medium (least the back one) so i can see better out the rear when backing up.
If you don't know your rights, its like you don't have any at all. Pre Paid Legal & ID Theft Services Restoration available... check out
http://www.deantaber.com
Old 05-05-2008, 07:35 PM   #20 (permalink)
Some Guy
Frankenstipe's Avatar
2007 Toyota Corolla S - '07 Toyota Corolla S
90 day: 29.56 mpg (US)
Hachi-Roku - '87 Acura Integra LS
Keeps the inside cooler so you don't have to use the A/C as much and use up more gas. Or if you don't use your A/C anyway and keep your windows rolled down then it will allow you to roll your windows up and increase your aerodynamics and use less gas.
I'm looking to do mine soon and getting 30% all around.
I may be crazy but at least I'm not sane.
http://www.cardomain.com/ride/3008712
Video: Fuel Economy Decrease with Opened Windows Peakster Aerodynamics 21 04-30-2008 12:13 AM
Window tint dremd EcoModding Central 4 04-27-2008 11:12 AM
When does having your windows down start to effect your mileage? Chris D. Aerodynamics 9 03-11-2008 12:15 AM
Windows down on VW Golf = 2.5% FE reduction MetroMPG Aerodynamics 2 11-28-2007 08:43 AM
Found a coastdown hill! Mini comparo: windows vs skirts vs hatchback MetroMPG Aerodynamics 4 11-27-2007 11:40 PM
