Old 07-25-2008, 12:35 PM   #31 (permalink)
NismoMax80's Avatar
Max - '04 Nissan Maxima SE
90 day: 24 mpg (US)
i would think the cost would be way more than anything eventually saved with slight FE gains???
my current project
Old 07-25-2008, 12:37 PM   #32 (permalink)
2k2Prot5 - '02 Mazda Protege5
90 day: 33.82 mpg (US)
Anybody care to post before/after FE for a simple mirror delete? This would be the same thing, but the cost goes towards the safety factor.
Old 07-25-2008, 12:54 PM   #33 (permalink)
Ex-lurker
i_am_socket's Avatar
Skeeter - '05 Toyota Corolla LE
90 day: 35.55 mpg (US)
I had a .6 mpg improvement tank-to-tank after my passenger delete, but isn't exactly reliable data. Anyone with a gauge that can do an A-B-A test? Did Metro do one already?
Old 08-12-2008, 07:10 AM   #34 (permalink)
Originally Posted by i_am_socket View Post
Jersey law is driver's side and rear-view mandatory, passenger side if the rear-view is blocked. I've gotten no problems from my passenger delete (though it really just looks like accident carnage at the moment).
An internal mirror would serve the same purpose, but I'd prefer the outside view and position adjustment that could come from an external video mount. Heck, if I could hook up the existing electric controls to change viewing angle...
Found this site for a rather convenient argument for video over mirrors (at least for those who prefer to allow computers to think for them): LINK
on the same link that coyotee bought his cameras and screens is a back up camera with monitor in rearview and it has a remote xy angle adjustment for $109 I think it is www.gooddeals18.com/product/plcm5800
Old 09-12-2008, 12:04 PM   #35 (permalink)
Hi,
I am very tempted to buy these for my car! How's the wiring done -- just plug the screen into the camera and power them up? Do both the camera nd he screen need their own power connection?
Originally Posted by Coyote X View Post
Mine was pretty cheap, $25 for the camera and the 3.5" screen for $53
I did it by cutting off the base of the stock mirror then using a tube that the cameras fit inside to fiberglass into the base. After the fiberglass was strong enough I filled and smoothed it with lightweight body filler before painting it. They work pretty good and give a lot wider range than a normal mirror. The passenger side screen is a bit small but it gets the job done. Drivers side works great. Only bad thing is I have only managed to put 125 miles on the car since putting them on I need to get out and drive some more
TIA
Old 09-13-2008, 04:58 AM   #36 (permalink)
Modding for Eris
Thalass's Avatar
SilverCivic - '08 Honda Civic
90 day: 28.69 mpg (US)
Originally Posted by tasdrouille View Post
Cameras won't cut it in Canada. The best you can do is get rid of the passenger side mirror and downsize the driver side mirror as long as it meets the minimal specs.
Canada's motor vehicle safety act:
111. (1) Any mirror referred to in this section that is installed on a vehicle shall
(b) be adjustable in the horizontal and vertical directions;
Maybe that's something to work on there. Rather than having a fisheye lens or pinhole, the camera should have a similar field of view that a mirror would provide, and have adjustment controls like power mirrors have. Even better would be adjustable aperture for night/day driving! I suppose you could do that electronically rather than mechanically.
That ought to satisfy some of the Man's objections at least.
Making do with a Honda Civic. Tesla Model 3 reserved. Still kinda want an SVX for fun, though.
Old 09-13-2008, 01:17 PM   #37 (permalink)
Legend in my own mind
trikkonceptz's Avatar
Evil Pumpkin - '08 Scion xD RS 1.0 #1633
90 day: 35.45 mpg (US)
Silent Silver Killer - '10 Honda Insight EX
90 day: 51.5 mpg (US)
I have since deleted my passenger side mirror and the only problem I'm having is backing in to spaces with visibility on that side.
As a fix, when I go to camera I will likely mount them in the front fenders recessed like an exhaust vent and low in the fender in order to see the ground and things like parking lines and such.
For now I will mount both screen directly in front of me @ the windshield so they are always in my line of site.
Thx NoCO2; "The biggest FE mod you can make is to adjust the nut behind the wheel"
I am a precisional instrument of speed and aeromatics
If your knees bent in the opposite direction......what would a chair look like???
Old 09-13-2008, 09:34 PM   #38 (permalink)
Hi,
I've been contemplating using the adjustments on the stock mirror. But if you think about it, using a camera eliminates the need to make any adjustments -- since the purpose of adjusting the mirror is so different drivers can see the mirror. With a camera and screen, the equivalent adjustment would be on the screen, not the camera.
Old 09-13-2008, 09:56 PM   #39 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
With a decent resolution fisheye camera, you could "unfisheye" the camera picture in software and pan up and down, left and right, on the monitor (and stabilize the picture), without introducing mechanical components that would be more prone to failure than their software counterparts.
Old 05-16-2011, 02:46 PM   #40 (permalink)
My new video cameras and screens arrived -- and boy the cameras are really small! They are about 5/8" in diameter x about 7/8" long. The holes in the mounting bracket are about 1 1/8" apart. I am going to have to try them out, but if they work well, or are better than my current cameras, I will make some fiberglass replacements for the stock mirror bases.
And, the screens did not come with stands, but I have stands from the old screens that should work.
Side mirror drag & effect on fuel economy - quantified MetroMPG Aerodynamics 179 11-10-2022 03:25 PM
Side View Mirror Downsize cfg83 Aerodynamics 20 07-13-2011 12:22 AM
Temporary side skirts? atomicradish Aerodynamics 9 07-02-2011 06:52 PM
Project HX - The flip side Vince-HX EcoModding Central 81 01-06-2009 10:57 PM
Article: Angry drivers torching traffic cameras in England MetroMPG The Lounge 6 01-03-2008 09:18 PM
