Old 03-10-2024, 11:05 PM   #21 (permalink)
That loses the advantage j-c-c suggested.
A Z-section would give you the horizontal attachment and a wickerbill.
________________
Because much of what is in the published literature is nonsense,
and much of what isn’t nonsense is not in the scientific literature.
-- Sabine Hossenfelder
Old 03-11-2024, 06:17 AM   #22 (permalink)
Old But New Ecomodder
LostinTransit's Avatar
never have liked the wickerbills plus the rear of the van doesn't need these things.. just the air tabs. I'm considering having the muffle repositioned as it siting upright and right behind the rear dead axle.. Since removing the full size spare.. there's plenty of space to retro fit another muffle in that area then add duel pipes. One thing thta concerns me is that the rear bumper cover hangs down and creates an area of drag I don't like. So I may have to have something created like a defuser. Next week heading to a fab shop/welder to have the spare tire bracket welded and talk to them about what can be done about a rear defuser.
The Following User Says Thank You to LostinTransit For This Useful Post:
aerohead (05-13-2024)
Old 03-11-2024, 08:03 AM   #23 (permalink)
You understand my use of "wicker bill" previously here was just an analogy as to shape and partially function, not to the typical rear DF wing use they are known for? Regardless liked or not, they are very effective for their original intended purpose of increasing DF when used on a rear wing.
The Following User Says Thank You to j-c-c For This Useful Post:
freebeard (03-11-2024)
Old 04-08-2024, 02:45 PM   #24 (permalink)
talked it over with the wife, and she doesn't want me to jerry rig the garden edging onto the van..
Old 05-11-2024, 01:28 AM   #25 (permalink)
Hows about gutters?
________________
BamZipPow (10-05-2024)
Old 05-13-2024, 01:25 AM   #26 (permalink)
Not really seeing the gutter solution, but it would maybe be a great partial mold for a custom hand laid up FG skirt.
Old 05-13-2024, 02:29 PM   #27 (permalink)
rear bumper 'drag'
Subaru spent a bit of wind tunnel time exploring the aerodynamics of their XT's rear bumper.
In order to reduce drag, the rear fascia was 'lowered' down to where a 'slow' diffuser might have lived, wrapping completely around, and forwards, to the end of the rear wheel arches, creating a pool of dead air underneath there within its boundary, as the rocker panel extensions, and wrap-around front airdam had done.
It's quite possible that Ford has 'optimized' the rear fascia, and arbitrarily reducing its depth could actually make things worse.
