Old 11-11-2011, 03:42 PM   #1 (permalink)
Buggie - '01 Vw Beetle TDI Gls
So... Who wants to try my new idea?
Take any Car, the lower the better, preferably 4 ft wide, more I you can buy wider material. Buy some plexiglass. THe more the merrier. Mount a 4x8 sheet on the roof and have it gently curve down until it touches the end of the hood. Mount the next sheet where the prior one ended, and carry on wih the arced plexy until you almostoch the road, maybe 4 inches up On the back do the same, until the car resembles an upside down dinner plate, or a speed bump, or a trapezoid with curved angles. The sides can also be covered with plexi, covering the wheels and mounting to the front and back pieces for support. if you feel energetic you can cover the belly of the car and eliminate all turbulent areas. Well almost.
I realize I might add a few pounds, extend the lenth of the car by a few feet, but it would be super aerodynamic. Almost No need for any other aero mods.
Old 11-11-2011, 04:47 PM   #2 (permalink)
You are not aware that basjoos did almost exactly that?
Old 11-11-2011, 06:58 PM   #3 (permalink)
Patrick's Avatar
Hot Tamale - '10 Toyota Prius III
Problem is you gotta keep it clean and Plexiglass scratches easily.
Old 11-11-2011, 07:09 PM   #4 (permalink)
Good luck with defrosting/defogging it too, as well as seeing through the rain- yes motorcycles don't have wipers on their fairings, but most of us look over the fairings more than through them.
Old 11-11-2011, 07:21 PM   #5 (permalink)
sides
The open spaces on the sides will cost you in aero. That is if they don't allow enough air in to rip it all apart
Old 11-11-2011, 08:24 PM   #6 (permalink)
That's why I said plexi on the sides too. No I did not know desjoos did that. Did it work?
Old 11-11-2011, 08:29 PM   #7 (permalink)
As far as I know he took it off.
Old 11-12-2011, 03:53 AM   #8 (permalink)
Sven7's Avatar
Boo Radley - '65 Ford F100
90 day: 13.28 mpg (US)
I think the problem was usability. Like others mentioned, it fogs up easily, is difficult to clean, has no wipers, distorts vision, etc.
If you want to remove your stock windshield and build a new one over the hood be my guest! That would be cool to see.
Old 11-12-2011, 01:38 PM   #9 (permalink)
The PRC.
The legend that is....
Old 11-12-2011, 08:51 PM   #10 (permalink)
JasonG's Avatar
05 DMax - '05 Chevrolet 2500HD
90 day: 18.48 mpg (US)
He also learned it made a minimal improvement over a facory sloped windsheild.
Hucho shows a chart of windsheild angles, basically there is minimal change until an angle much more vertical than modern autos have.
As an added point, plexi is much more expensive than foam/fiberglass.
FRF is also easier to shape with a sander or hot wire.
I can't understand why my MPG's are so low..........
21,000lb, 41' Toy Haulers are rough on FE!
