Old 02-01-2011, 10:40 AM   #31 (permalink)
Mechanical engineer
Vekke's Avatar
Siitin - '98 Seat Cordoba Vario
90 day: 58.56 mpg (US)
VW Lupo 3L --> 2L - '00 VolksWagen Lupo 3L
Diesel
90 day: 104.94 mpg (US)
A8 luxury fuel sipper - '97 Audi A8 1.2 TDI 6 speed manual
90 day: 64.64 mpg (US)
Audi A4B6 Avant Niistäjä - '02 Audi A4b6 1.9tdi 96kW 3L
90 day: 54.57 mpg (US)
Tourekki - '04 VW Touareg 2.5TDI R5 6 speed manual
90 day: 32.98 mpg (US)
A2 1.4TDI - '03 Audi A2 1.4 TDI
90 day: 45.68 mpg (US)
A2 1.4 LPG - '02 Audi A2 1.4 (75hp)
90 day: 24.67 mpg (US)
Here goes my current test setup. My current wheel spokes come more outer than rim so I have black soft material to bring that cover littlle bit outwards. Now the polykarbonate should not get scrapes... At the moment it comes too much off there is about 13 mm gap between rim and hubcap.
polykarbonate hubcap.jpg - Windows Live
This way you dont need to drill two holes to your hubcaps, but the attachement is difficult. With this you need to attach it behind/inside the wheel. Better version is coming which will solve that problem and that will be the serial version . Serial versions attaching time estimation is one minut per capsel, if those holes are already drilled...
https://www.linkedin.com/in/vesatiainen/
Vesa Tiainen innovation engineer and automotive enthusiast
The Following User Says Thank You to Vekke For This Useful Post:
TOOQIKK (02-01-2011)
Old 02-01-2011, 11:11 AM   #32 (permalink)
Grasshopper
alohaspirit's Avatar
Makai - '01 Toyota Echo 4D Auto
90 day: 34.45 mpg (US)
New Galaxy - '07 Toyota Prius
90 day: 42.15 mpg (US)
interesting
is that glue or magnets?
Past Present Future?
Old 02-01-2011, 11:44 AM   #33 (permalink)
Mechanical engineer
Vekke's Avatar
Diesel
Those are with this kind of "brackets" :
Browse Catalog - Cable Ties & Accessories - FTH-9 -Cable Tie Mount,Snap In
and regular zipties. Look also the previous and next pictures in my picture folder...
If you use those with regular ABS you paint those caps to any color. At the moment those come only in white. Much cleaner look than with regular zipties...
I will also try these if they can hold up:
http://www.richco.co.uk/products/cab...&grpcode=G1455
The Following 3 Users Say Thank You to Vekke For This Useful Post:
BamZipPow (02-01-2011), Boreas (03-05-2011), cfg83 (02-01-2011)
Old 02-01-2011, 01:01 PM   #34 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
Vekke -
Bravo! I love the C-thru cover because I can "C" how it works. Can you unmount it without cutting the zipties?
CarloSW2
American Solar Energy Society
Old 02-01-2011, 01:33 PM   #35 (permalink)
Mechanical engineer
Vekke's Avatar
Diesel
Not this version. Unless you use zipties which can be opened. In this case it would be difficult at least with 15" wheels. It took about 15 minutes to attach that to the car on the ground. Do notice that I have also added extra panel inside the rear tire to smooth the airflow so I have to attach those from the upper part of rim and working behind the rim... In bigger wheels there is more room for your hands and job is much easier.
Old 02-01-2011, 05:21 PM   #36 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by Vekke View Post
Maybe you could try to ask what tape they use on them ?
If they'd use 3M VHB tape, i don't think they'll ever come off.
<Edit>
I see they're also available without tape, so you could choose your own and add some tape to a set.
</edit>
Old 02-02-2011, 04:24 AM   #37 (permalink)
Mechanical engineer
Vekke's Avatar
Diesel
<Edit>
</edit>
They said that there is new version coming or it was this, which will hold even if you attach it to wet surfaces. Anyway I will test these what I got.
Old 03-04-2011, 06:10 PM   #38 (permalink)
Grasshopper
keeping it going...
Old 03-05-2011, 03:41 AM   #39 (permalink)
Mechanical engineer
Vekke's Avatar
Diesel
Sorry havent been able test those brackets yet :/.
Old 03-08-2011, 12:29 PM   #40 (permalink)
Mechanical engineer
Vekke's Avatar
Diesel
Rengas - Jäälläajon maailmanennätys - Nokian Renkaat
Nokian tyres set new land speed record for winter tires 331,61 km/h. Check out the smooth hubcaps. They use also bolts on the outer edge.
aerohead (03-08-2011)
