Old 01-24-2015, 06:49 PM   #1 (permalink)
Milk-seeking missile
Jooseppi Luna's Avatar
The Old Soldier - '04 Toyota Corolla LE
90 day: 42.2 mpg (US)
As my mom says, "that thing" - '82 Mercedes-Benz 300SD
The Buick - '94 Buick Century Special
UG reads like I don't have DFCO, and some other UG questions
I just set up an UG in the Corolla last Monday, and when I am coasting in gear (which I avoid as much as possible), the UG reports MPG readings in the hundreds, but not the 999.9 MPG that I would expect to see. This has been the case all the way from 3k to 1.1k RPM, so it's not like DFCO is just kicking in at certain RPM ranges. Any idea what's going on? The Corolla should have DFCO...right?
Also, sometimes when I turn the key into accessory when pulling into a parking spot, the UG will read 999.9 MPG; other times, it read 00.0 MPG. I can't figure out what is causing the different readings.
Old 01-27-2015, 04:25 PM   #2 (permalink)
What brake pedal?
digital rules's Avatar
Silver Streak-5M - '05 Toyota Corolla S
90 day: 42.41 mpg (US)
Are you using the 8 gauge per page display? I only see DFCO dispalyed when using the 4 or 6 gauge per page display. When on 8 guage mode, I see exactly what you are describing.
If not there is an adjustment for DFCO detection that may need to be dialed in. Forget what it is called but can check when I get home tonight.
The Following User Says Thank You to digital rules For This Useful Post:
Jooseppi Luna (02-04-2015)
Old 01-27-2015, 04:40 PM   #3 (permalink)
Furry Furfag
Baltothewolf's Avatar
Winsight - '00 Honda Insight
Miaderp - '95 Mazda Miata
90 day: 28.53 mpg (US)
My dad has an 04 Corolla LE auto and it doesn't have DFCO. At least if it does, I couldn't feel it.
Old 01-27-2015, 04:54 PM   #4 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Are you sure you turned on the DFCO function on the UG? I had to turn it on and enter some basic engine info, I think.
Old 01-27-2015, 05:23 PM   #5 (permalink)
Furry Furfag
You gotta see the number to 7x the engine size.
Old 01-27-2015, 05:54 PM   #6 (permalink)
vskid3's Avatar
Civic DX (sold) - '97 Honda Civic DX
90 day: 34.15 mpg (US)
GTO (sold) - '04 Pontiac GTO
90 day: 22.62 mpg (US)
Green Brick (sold) - '06 Ford Escape Hybrid
90 day: 31.93 mpg (US)
A quick way to check if you're in DFCO with a manual tranny is to turn off the ignition while coasting in gear. If the rate of deceleration stays the same, you were in DFCO. If it increases, you weren't.
Camry Thread
E-Bike Thread
The Following User Says Thank You to vskid3 For This Useful Post:
COcyclist (01-28-2015)
Old 01-27-2015, 05:59 PM   #7 (permalink)
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
Originally Posted by Jooseppi Luna View Post
I just set up an UG in the Corolla last Monday, and when I am coasting in gear (which I avoid as much as possible), the UG reports MPG readings in the hundreds, but not the 999.9 MPG that I would expect to see. This has been the case all the way from 3k to 1.1k RPM, so it's not like DFCO is just kicking in at certain RPM ranges. Any idea what's going on? The Corolla should have DFCO right?
I got the ScanGuage first and got used to it in my TDi. I picked up an Ultraguage and have been disappointed. Evidently it will not show DFCO in a diesel at all and the instant mpg was way off when I calibrated according to the manual for my Grand Cherokee CRD. I had to set the engine size to 1.1 liter to get it close. I should have spent a little more and gotten another ScanGuage, especially in the diesel. More user friendly too IMHO.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
Old 01-27-2015, 09:11 PM   #8 (permalink)
What brake pedal?
I thought all 9th generation Corollas had DFCO. But then again drive by wire wasn't incorporated until 2005, so maybe not??
Old 01-27-2015, 10:03 PM   #9 (permalink)
Not bad for a machine
dirtydave's Avatar
Maechunbu - Retired - '00 Kia Sephia 1.8I4 16VDOHC
Last 3: 45.28 mpg (US)
Slasher - '96 Chevy Corsica 2.2L 3speedauto
Duct Tape Aero Crew
Team Chevy
90 day: 34.76 mpg (US)
My car doesn't have DCFO Its not on every vehicle.
Old 01-28-2015, 07:09 PM   #10 (permalink)
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
If you have DFCO, the easiest way to tell is to watch you open loop/closed loop display. Open loop while decelerating means DFCO, even if the gauge is still reading normal MPG. You can then fine tune the gauge to read correctly (usually).
The Following User Says Thank You to oldtamiyaphile For This Useful Post:
