Old 10-15-2011, 03:22 PM   #11 (permalink)
2.657% delta Cd
Originally Posted by Soulster View Post
Put on the grill block for aero testing:
So it does look statistically speaking it does do some aero help 0.35mpg whoopeeeeee... I'm sure it helps warm the car up faster in the morning, but how do test that for MPG improvement? I've watched the scan gauge and it shaved 2miles off the warm up time so it's doing something... But I have no clue as to MPG testing. Any Ideas?
At 55-mph,the delta-mpg/delta-CdA relationship is 1-to-2.Your mpg gain indicates a drag reduction of 2.657,and since you didn't change the frontal area,it's all coming off the Cd.
kia, soul
Permanent Aluminum Grill Block and Belly Pan Markmysite EcoModding Central 41 02-27-2014 09:22 PM
Lower Grill Block 2005 Honda Civic Arminius EcoModding Central 12 10-04-2011 12:31 AM
How to: Kia Soul front grill block (my first mod :) ) Soulster Aerodynamics 9 05-06-2011 04:31 PM
Grill Block Summary 4536 Aerodynamics 19 07-22-2010 11:55 AM
Spring mounted Grill Block cfg83 EcoModding Central 32 04-19-2009 06:00 PM
