Old 09-16-2013, 04:09 PM   #41 (permalink)
Please explain which way that tube is pointing. I cannot tell if the flat or tapered side faces forward.
Old 09-16-2013, 06:20 PM   #42 (permalink)
Lots of Questions
Motor-Rolla - '01 Toyota Corolla LE
90 day: 28.3 mpg (US)
Gaia - '99 Toyota 4Runner SR5 Highlander
90 day: 19.78 mpg (US)
Gaia - Round 2 - '99 Toyota 4runner SR5 Highlander
90 day: 17.92 mpg (US)
On most of those new bike frames (that I've seen), the taper is forward facing. I wonder what flipping it around would do for a biker (especially a racer).
Don't forget to like our Facebook page!
Best EM Quotes:
It has been said, that if you peel the duct tape back on Earth's equator, you'll find that the two hemispheres are held together with J B Weld.
Originally Posted by Dan9 View Post
subscribed with a soda.
If you're burning,and someone throws gasoline on you,there will be a localized cooling effect, but you're still on fire.
The Following User Says Thank You to jeff88 For This Useful Post:
Xist (09-16-2013)
Old 09-17-2013, 01:50 AM   #43 (permalink)
HypermilerAX's Avatar
AX - '95 Citröen AX
307 - '04 Peugeot 307 SW
I'm myself a cat 2 racer. On a traditional bike, the last thing we're looking at is aero as most of the drag is coming from our position and aero effect is much reduced when drafting. We're looking at weight and stiffness. For individual efforts, time trials bikes are used. Heavier (17 lbs) but more aero.
Citroën AX 1.5 D 430.000 km
Peugeot 307 SW 2.0 HDI 136 195.000 km
The Following User Says Thank You to HypermilerAX For This Useful Post:
jeff88 (09-17-2013)
Old 09-17-2013, 06:37 PM   #44 (permalink)
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
Originally Posted by orange4boy View Post
Too bad they didn't test that tube profile the other (better) way around.
Trek designed a carbon fiber bike with similar profiles (although more of a full Kamm shape) to be more aerodynamic in crosswinds.
"Unlike a conventional airfoil, the KVF tube shape retains full aero benefit at yaw (crosswind). The virtual tail bends to maintain its aero shape in the presence of the most prevalent crosswinds. The virtual-tail truncated tube shape allows us to use less material, for a lighter yet stiffer frame."
Crosswinds are significant at the lower speeds of bicycles. A car or motorcycle going 60 mph will be less negatively effected by a 10 mph crosswind than the bicycle.
Speed Concept 9 Series - Feature tour - Trek Bicycle
Click on KVF tube shape.
That said, aero drag is pretty significant at 30 mph or even 10 mph with a 20 mph headwind. Ask any cyclist.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
Old 09-17-2013, 09:16 PM   #45 (permalink)
If you are riding 30 MPH forward, then the wind is already pushing 30 MPH against you. If you have a 10 MPH crosswind, exactly what are the forces against you? Can I use the Pythagorean Theorem? 30² + 10² = 31.6something?
That is 5.4% more air resistance.
That is enough to be irritating.
I do not understand how you could make a shape aerodynamic for 270°, winds and cross-winds, I would think that you would make compromises.
Old 09-25-2013, 08:39 PM   #46 (permalink)
More bike or bicycle stuff.
Aerodynamic Drag Chart For Human Powered Mobility
Cozy Beehive: Aerodynamic Drag Chart For Human Powered Mobility
COcyclist (09-27-2013), Fat Charlie (09-26-2013)
