Old 08-15-2008, 02:41 AM   #11 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
iHero -
Originally Posted by iHero View Post
Looks like BMW is building a gas / steam hybrid.
BMW Developing a Steam/Gas Hybrid Engine : TreeHugger
I really like this part :
Even more impressive: the drive has been designed to be retrofitted into existing gasoline-only Beemers, meaning that the entire fleet of BMWs could incrementally reduce fuel consumption almost overnight.
Retrofit-Mania!!!!
CarloSW2
American Solar Energy Society
Old 08-15-2008, 05:00 AM   #12 (permalink)
Mr. Blue Tape
azraelswrd's Avatar
AzxA - '06 Scion xA
90 day: 42.72 mpg (US)
+15% efficiency with steam boosters? Intriguing...
My 5 pillars of fuel efficiency:
  • driving style
  • aerodynamics
  • tires
  • weight reduction
  • engine maintenance
Old 09-06-2008, 09:07 AM   #13 (permalink)
Looks like another company working the steam option -- there is obviously something to this idea.
Clean Power Technologies still working on new steam-assisted cars - AutoblogGreen
Old 09-06-2008, 04:13 PM   #14 (permalink)
Big Dave's Avatar
The Red Baron - '00 Ford F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Chevrolet Impala SS
90 day: 21.03 mpg (US)
Plus 15% efficiency is pure ad-man's hype. Plus 1% would be more like it.
There are a lot of car companies on the ropes and MPG is a hot selling point. If they could really deliver a 15% improvement with Rankine cycle compounding, why don't they? Could it possibly be they know they cannot deliver?
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
Old 09-06-2008, 04:26 PM   #15 (permalink)
Wicked Wanda - '99 VW Beetle GLS
90 day: 29.59 mpg (US)
Green Monster - '99 Ford Explorer Sport
90 day: 16.73 mpg (US)
Dad's Taxi - '99 Honda Odyssey EX
90 day: 24.23 mpg (US)
When BMW started working on it in 2005 they predicted it would be 10 years before a production model was ready. There's a ways to go yet.
Old 09-06-2008, 06:44 PM   #16 (permalink)
With the amount of heat pooring out of any ICE vehicle after 15 minutes -- a simple design of copper tubing, small turbine and and alternator -- could save a fair amount of gas.
If you have a short commute -- steam will never work except for recharging.
I think the solar collector idea has merit for recharging during work ours too --much more so than solar panels.
I'd build one -- but my two prototypes severly limit any project time.
Right or Wrong ? Does more IR than UV pass through the atmosphere?
Old 09-06-2008, 10:26 PM   #17 (permalink)
Big Dave's Avatar
Bill Lear (daddy of the Lear Jet) tried this back in the 70s. It wasn't worth the effort.
4" Slam
Old 09-06-2008, 10:52 PM   #18 (permalink)
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
Actually plus 30% was a reality on large ship size motors and was employed sucessfully but caused contamination and subsiquent daily maintenance, but a ship also has all the room in the world for such engines, a small version would need to use dangerous low boiling point liquids to be effective, especially given that most of the motors heat goes into the radiator fluid at relatively low temps which is hard to recover usefully.
Given that 50-75% of your motors full energy is lost in the form of heat this is no small energy source, sadly heat is difficult to make locomotion out of.
There is a guy in Australia that has been converting full size cars and trucks to steam since the 70's. A well designed capillary steam engine weighs no more than a standard diesel. But then you have to take care on what type of water you use and again the irritating cleaning.
Well worth more reasearch, main issue developing a fully contained unit like AC to handle the dangerous low boiling point liquids available or a safe low boiling point liquid needs to be developed.
And on a side note, I have long wondered why engine heat wasn't used to make passive AC. It wouldn't require any extra power from the motor and would be Always on for better or worse.
Old 09-07-2008, 09:56 AM   #19 (permalink)
Big Dave's Avatar
Bill Lear tried an organic soup he called "Learium" to replace water as his working fluid. Lear found out why water was the better fluid.
You could use an adsorption refrigeration system to cool your car but it would be huge. Adsorption refrigeration is about a third the efficiency of thr Rankine cycle used today.
There is nothing new under the sun. That's completely true in energy technology. Somebody has already tried it. What works is what is in use. What doesn't work is a museum curiosity.
Material and theoretical advances have triggered a few new ideas. Algal biofuels. Aneutronic fusion. Vanadium redox batteries. Not much else.
4" Slam
Old 09-07-2008, 02:18 PM   #20 (permalink)
Since when has mpg been a big selling point? June, maybe? On experience to date, it takes a LOT longer than 3 months for auto executives to pull their heads out of their butts. Then consider how many years they've spent going in front of Congressional committees and saying that they couldn't POSSIBLY meet those CAFE standards. So now they're supposed to turn around and say "Gee, it looks like we could have done it all along"?
When I think about the actions of the auto manufacturers since the '70s oil embargo, and even before, I can only conclude that they simply don't WANT to make cars that get good mpg.
Converting Exhaust Heat to Electricity SuperTrooper General Efficiency Discussion 13 03-20-2010 06:03 AM
1992 Metro sedan needs a new engine - What/Where/How - advice appreciated greatly! Crono EcoModding Central 26 11-18-2008 01:42 AM
Heat engine block for efficiency? bennelson EcoModding Central 43 08-12-2008 09:45 PM
Moving air intake into the engine compartment? pasadena_commut Aerodynamics 5 07-25-2008 03:24 PM
Coasting experiment: engine on VS engine off on a fixed route = 12.9% gain MetroMPG Hypermiling / EcoDriver's Ed 6 02-22-2008 08:38 AM
