Old 09-14-2015, 08:19 PM   #1 (permalink)
JRMichler's Avatar
Nameless - '06 GMC Canyon
90 day: 37.45 mpg (US)
22 Maverick - '22 Ford Maverick XL
90 day: 39.26 mpg (US)
Test of P&G vs DWL
I finally did a test of P&G vs DWL on the highway. Conditions were ideal for a P&G test - no traffic behind me, level road, 65 degrees, and a light tailwind. MPG is from my Scangauge, which reads about 5% or 6% low. I do not bother to better calibrate it because the relative readings are good.
A stretch of DWL resulted in 36 MPG on the Scangauge. The road is level, with slight rises and falls of 2 to 4 feet. I tested P&G between 50 to 55 MPH, timed to take advantage of the road undulations, slight as they were. Results: P&G gave me 40 MPG.
I do not normally P&G on a level road because glide distances are shorter than the accelerations. A typical 50 to 55 pulse and glide is less than a mile. And because gliding below 55 MPH in a 55 limit on a two lane road with limited passing is too rude.
The MPG difference between DWL and P&G increases at slower speeds, and with larger speed differentials.
The Following 3 Users Say Thank You to JRMichler For This Useful Post:
Daox (09-15-2015), Joggernot (09-15-2015), MetroMPG (09-14-2015)
Old 09-15-2015, 10:54 AM   #2 (permalink)
Thanks for sharing your results.
