Old 09-28-2013, 09:58 AM   #101 (permalink)
Minor appearance preference, but I added a line clear to the screen label display section:
Code:
void doCursorUpdateMain(void) {
	doMainScreenDisplay(); // call the appropriate display routine
	printStatusHold(findStr(displayFuncNames, screenCursor[(unsigned int)(mainScreenIdx)])); // briefly display screen name
	gotoXY(0, 1);
	clrEOL();
Old 09-28-2013, 11:46 AM   #102 (permalink)
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
Originally Posted by josemapiro View Post
To remove any doubt, the scheme should I use is what is depicted in the image?
Thank you
José Rodrigues
Swap the 5 VDC and the ground connections, and you'll exactly have it.
Old 09-28-2013, 11:49 AM   #103 (permalink)
MPGuino Supporter
t vago's Avatar
Code:
	gotoXY(0, 1);
	clrEOL();
Fair enough - that can be put in via an "#include," as well.
Old 09-28-2013, 12:01 PM   #104 (permalink)
MPGuino Supporter
t vago's Avatar
Code:
		if (!(timerStatus & tsButtonsUp)) { // see if any buttons were pressed, display a brief message if so
			j = buttonState;
			timerStatus |= tsButtonsUp; // reset keypress flag
			bpPtr = (PGM_P)pgm_read_word(&buttonPressAdrList[(unsigned int)(menuLevel)]);
			while (true) {
				i = pgm_read_byte(bpPtr++);
				if ((i == buttonsUp) || (j == i)) break;
				bpPtr++;
			gotoXY(0, 0);
			if (j != buttonsUp) callFuncPointer((char *)(bpPtr)); // go perform action
This is near the end of the code. The boldfaced things are the things that need changed.
The Following User Says Thank You to t vago For This Useful Post:
Ardent (09-29-2013)
Old 09-28-2013, 12:50 PM   #105 (permalink)
Where have 5V, becomes GND, where have GND, becomes 5V, is correct?
Code:
         o-----------o-----------o-----------o-----------o--o GND
    R2   |      R3   |      R4   |      R5   |      R6   |
 o--vvv--o   o--VVV--o   o--vvv--o   o--vvv--o   o--vvv--o
 |  2,2k     |  4,7k     |  10k      |  22k      |  47k
 o           o           o           o           o
 o           o           o           o           o
 |           |           |           |           |  R1
 o-----------o-----------o-----------o-----------o--vvv--o--o 5V
 left      middle     right     Extra#1   Extra#2|  1k
                                                 o----------o PC3
Thank you
José Rodrigues
The Following User Says Thank You to josemapiro For This Useful Post:
t vago (09-28-2013)
Old 09-28-2013, 01:17 PM   #106 (permalink)
MPGuino Supporter
t vago's Avatar
Yep - That's also going into the code comments!
Old 09-28-2013, 02:02 PM   #107 (permalink)
I've done it with that intention, is easier to intender.
Thank you
José Rodrigues
Old 09-29-2013, 09:38 AM   #108 (permalink)
Thanks, I'll add that as soon as I can. I didn't enable useSavedTrips so I don't want to loose my current tank data.
Old 09-29-2013, 05:00 PM   #109 (permalink)
AndrzejM's Avatar
Berta - '97 BMW 318 tds Compact
90 day: 62.03 mpg (US)
Charlie - '07 Citroen C4 Grand Picasso Exclusive
90 day: 37.58 mpg (US)
Corsa - '05 Opel Corsa C
90 day: 53.22 mpg (US)
Mruczek - '03 Audi A2
90 day: 60.61 mpg (US)
You got coastdown testing to work? That would be cool!
Code:
//Coast down time
unsigned long coasttime(void){
int t1;
int t2;
int v1= instantvehiclespeed();
int ctime;
if (v1>parms[CoastSpeedMax]) {
	t1=0;
	t2=0;
if (v1 == parms[CoastSpeedMax]) {t1 = tank.time();}
if (v1 == parms[CoastSpeedMin]) {t2 = tank.time();}
ctime = t2 - t1;
return ctime;
//Coast down distance
unsigned long coastdistance(void){
int d1;
int d2;
int cdistance;
int v2 = instantvehiclespeed();
if (v2>parms[CoastSpeedMax]) {
	d1=0;
	d2=0;
if (v2 == parms[CoastSpeedMax]) {d1 = tank.distance();}
if (v2 == parms[CoastSpeedMin]) {d2 = tank.distance();}
cdistance = d2 - d1;
return cdistance;
This is my code, and it works , but with "canadian" version. So I think it should be rewritten for your version.
Gerhard Plattner: "The best attitude is to consider fuel saving a kind of sport. Everybody who has enough money for a strong car, can drive fast and hit the pedal. But saving fuel requires concentration, self-control and cleverness. It's a challenge with the nice effect of saving you money that you can use for other more important things."
Old 09-30-2013, 06:33 PM   #110 (permalink)
I've been testing the Multiplexed Analog buttons, and it works but not correctly, the first and third seem to do the same functions, as the middle button only changes the brightness, and pro comportace times as the first, the extra 1 to precionar appears (btn 8 pressed), the extra 2 has not tested because had no 47k resistance.
What is the tolerance of the resistors you used? I'm using resistors with 5% tolerance.
I think the problem I'm having now, has to do with the values ​​that each sends resistance, which may vary slightly and complicate the whole process, but at least I can see the system moving.
Thank you
José Rodrigues
