Old 10-30-2012, 04:34 PM   #31 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
Originally Posted by rmay635703 View Post
It is my belief that long term proper testing is the only way to really know how a tire will affect FE on any given car.
I think the tires load rating (and loading), PSI and aero drag likely play more of a role than their size in terms of FE. (although they are also related)
Here's my take (and experience), In the day to day reality world of a slight upsize on a car (trucks are another discussion),
1. the load rating is higher so it's not a factor.
2. the width is actually SLIGHTLY narrower, but even it slightly wide, aero gain or lose is non-mearsurable and not an issue.
3. PSI - you should run the desired PSI (40+) regaurdless of size. Since you would run the same psi, then psi is not an issue
4. Size - need atleast a 5% increase in diameter for it to statisticly matter.
5. If you go from a high performance tire to a LRR tire you will see an increase even w/ same size. That is why it's important for all posters to state the full size and type of tire.
6. Downsizing to gain areo is UNSAFE. Period. running narrower (defined as 90% or less) tires is just too risky
Let me give you an example. driver A is got his car all stripped down, scangauge in the ashtray and running donut tires. He is in an accident w/ driver B in a normal car. If I am driver B's attorney......I'm going to own driver A. I wont settle for the insurance claim. I'm going after criminal malice, neglect, ........ I'm sure you see where this can head. When you step out and 'mod' a vehicle uotside the standards, you are setting yourself up for truoble, ESPECIALLY if you didn't notify your ins company of the mods.....
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
The Following User Says Thank You to mcrews For This Useful Post:
mchlbk (11-07-2012)
Old 10-30-2012, 04:34 PM   #32 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Interesting. How might load rating affect FE?
Old 10-30-2012, 10:12 PM   #33 (permalink)
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
It can go either way, if you run the tire at rated pressure at much less weight than it is rated its RR is lower than the same tire loaded up to its rating.
This can mean a smaller tire can reduce aero+RR on the rear of many FWD vehicles because the weight isn't there. (per experience)
Old 10-30-2012, 10:58 PM   #34 (permalink)
mcrews's Avatar
can you be more specific?
ECO MODS PERFORMED:
First: ScangaugeII
Old 11-01-2012, 07:43 AM   #35 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Less sidewall flexing and less tyre deformation is good for FE - that's what you get with a higher LI tyre when it's only lightly loaded - provided most factors remain the same, i.e. profile, pattern, rubber composition, pressure.
Tyre weight will normally be a bit higher on the higher LI tyre though.
OTOH, higher LI tyres often also have higher allowed pressures to cope with the higher loads.
Wether the effect is measurable on the road when you're using say LI 94 tyres instead of 91 ?
The Following User Says Thank You to euromodder For This Useful Post:
California98Civic (11-01-2012)
Old 11-01-2012, 09:05 AM   #36 (permalink)
Cyborg ECU
That makes a lot of sense. (I take it "LI" is a way of referring to "load rating".)
Old 11-01-2012, 11:13 AM   #37 (permalink)
Load Index, after the 195-65-15 there's a 89S or something 89 is Load Index number S is the speed rating.
89 good for 1278 lbs, 91 is 1356, 95 is 1521 lbs for that size, don't know if same for all sizes.
The Following User Says Thank You to roosterk0031 For This Useful Post:
Old 11-03-2012, 04:26 PM   #38 (permalink)
EcoModding Minded
Chris D.'s Avatar
Lunar Mist - '02 Toyota Tacoma SR5
90 day: 25.31 mpg (US)
Silver Streak - '08 Toyota Corolla S
90 day: 38.25 mpg (US)
Send a message via AIM to Chris D.
What are you doing for speedometer and trip odometor totals?
If your speedometer reads 60, wouldn't your actual speed be around 63ish +?
How do you calculate your fuel economy?
Old 11-03-2012, 07:31 PM   #39 (permalink)
mcrews's Avatar
Originally Posted by SecondWind View Post
As I am the OP on this thread, I'll say that the ScanGauge was re-calibrated between testing the OEM tires and the "tall tires". As I recall, the OEM tires used -3% setting, and the "talls" +7%. In both cases, the ScanGauge error was less than 0.1 mile in 10 miles. AFAIK, an improperly adjusted ScanGauge will affect both MPH and MPG readings.
chris D, pls read post #22 or re-read it above.
ECO MODS PERFORMED:
First: ScangaugeII
Old 11-05-2012, 04:42 AM   #40 (permalink)
92 Camry - '92 Toyota Camry LE
90 day: 26.81 mpg (US)
97 Corolla - '97 Toyota Corolla DX
90 day: 30.1 mpg (US)
Red F250 - '95 Ford F250 XLT
90 day: 20.34 mpg (US)
Matrix - '04 Toyota Matrix XR
90 day: 31.86 mpg (US)
White Prius - '06 Toyota Prius Base
90 day: 48.54 mpg (US)
This is an interesting thread. I too thought about increasing the size of my tires (needed to be replaced anyway), but oped to go with factory since the gearing isn't bad.
On past experence prior to ecomodder... my dad owned a 1992 Buick Century with a 3300 v6. His tires were about shot, and going on the cheap, a I had a 92 chevy lumina I was scrapping out with good tires. The lumina's tires were taller and quite a bit wider, enough to hit *something* when turning really shape around corners or parking lots. He claimed a MPG loss and it took off slower. He wasn't exactly an eco driver though, and I don't have any good tracking/numbers to give. He probably didn't count for the tire size change, and the mpg drop wasn't enough to bother getting different tires (like 2-3mpg drop, car normally got like 26mpg). I'm pretty sure the tires were 8-10% taller.
