Old 08-19-2018, 11:04 PM   #21 (permalink)
Originally Posted by euromodder View Post
Is that a C-130 prop in the garage ? ?
I didn't notice the propeller, only what appears to be a can-type combustor chamber.
Old 08-20-2018, 07:26 AM   #22 (permalink)
Neutral is my favorite
The Black Pearl - '03 Mercury Marauder 300A
Team Panther
Land Yacht - '08 Lincoln Navigator L Ultimate
90 day: 15.89 mpg (US)
Tank of Justice III - '97 Ford Crown Victoria HPP
Team Panther
90 day: 24.84 mpg (US)
Correct. Can-annular combustion.
Yes, those are C-130 props.
No, that is not my garage. It's my shop at work. It's nice to bring your car inside during the winter to melt off all that crap that builds up in the wheel wells.
And to do your own oil changes inside in February.
FYI, I am a jet engine mechanic, lol.
-ryan s.
1997 Ford Crown Victoria HPP- "Tank of Justice III" 194k - 578.9 miles on ONE tank
2003 Mercury Marauder- 63k, not so fuel efficient; #1,548 of 11,052
2008 Lincoln Navigator L - 244k (don't ask about mpg)
The Following User Says Thank You to svt98t For This Useful Post:
Lemmy (01-18-2020)
Old 08-22-2018, 03:36 AM   #23 (permalink)
One of my uncles is an aircraft mechanic, but IIRC he's more used to piston-engined aircraft.
Old 09-13-2018, 11:18 AM   #24 (permalink)
Team Panther
Team Panther
Looking at lowering the back to match the front. Also want to install 2.73s in the back before winter. I can't forget to swap out the gear on the VSS so the speedometer reads proper.
Maybe look around and get some weight reduction done.
-ryan s.
Old 09-13-2018, 11:35 AM   #25 (permalink)
It's a ford. vss is done in software via correction factor on tire size or on some obd2, transmission gear.
Old 09-14-2018, 09:30 AM   #26 (permalink)
Team Panther
Team Panther
They didn't eliminate the VSS on Panthers until 2003. 03+ need the software/ tune to correct it.
All -02's have a VSS with interchangeable gear.
-ryan s.
Old 12-27-2018, 09:24 AM   #27 (permalink)
Team Panther
Team Panther
Found that my mileage was starting to drop off. Discovered that my left rear tire was low. Filled all tires back up to 35 psi. Oil changed and transmission fluid added.
Back up in the 400+ mile per tank range again. Back to hypermiling and getting even better economy.
-ryan s.
Old 01-10-2019, 03:57 PM   #28 (permalink)
Team Panther
Team Panther
Offically at 149 lbs removed, with the goal of 200 lbs total in sight.
There's a few things I have in mind. Oh, if the A/C goes, I'm totally ripping the whole system out of the car. It's only in right now because it works.
Still kicking along at high 23s mpg now, for the entire tank, which is pretty good, seeing how its rated at 15 city, 18 combined, 23 highway.
-ryan s.
Daox (01-10-2019)
Old 01-10-2019, 04:08 PM   #29 (permalink)
Remember back in 97 when it was rated, they used REAL gasoline which had more BTU's.
Old 01-11-2019, 08:21 AM   #30 (permalink)
Team Panther
Team Panther
These are the updated numbers.
Next road trip, I'm going to use the ethonol-free 91 octane to see what it can do..
-ryan s.
