Old 05-13-2011, 12:47 PM   #1 (permalink)
Easter McoModder
SwamiSalami's Avatar
'99 Subaru OLL 2.5L - '99 Subaru Outback Legacy Limited
90 day: 22.57 mpg (US)
Rabbit - '08 VW Rabbit S
90 day: 32.93 mpg (US)
TDI NB Disabling Daytime Running Lights
I found a great diy step-by-step online showing how to disable DRLs.
Here: Disabling Daily Runing Lights (DRL's) - How-To - NewBeetle.org Forums
I have but one critique. And, that is that the pictures of the connection are a bit misleading (or at least they were to me).
In an attempt to make it clearer which connection is to be disrupted, I have taken what I feel to be a better picture.
Good for around a 1.5% mpg improvement!!!
good luck
The Following User Says Thank You to SwamiSalami For This Useful Post:
aClockworkLuka (08-27-2011)
Old 05-13-2011, 02:12 PM   #2 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Holy smoke !
Ditching the DRLs was a 1.?? euro software mod on my Volvo
Old 05-13-2011, 02:20 PM   #3 (permalink)
Easter McoModder
According to research I've done this mod is good for around 1-1.5% improvement.
Here's the link: HowStuffWorks "How much extra gasoline would Americans use if daytime running lights were mandatory?"
Great article, too, btw.
Old 05-13-2011, 02:51 PM   #4 (permalink)
UFO
UFO's Avatar
Colorado - '17 Chevrolet Colorado 4x4 LT
90 day: 23.07 mpg (US)
Do you know how much current the DRLs draw? 1.5% sounds like a whole lot of improvement, yet very difficult to measure - 1% is less than half an mpg.
I'm not coasting, I'm shifting slowly.
Old 05-13-2011, 03:10 PM   #5 (permalink)
Easter McoModder
I sure don't. I know what you're saying, though. very hard to measure indeed. I'm not going to rack my brain trying to figure it out so specifically.
All that I know is that with my kammback attached I get 55.4mpg. if this improves mpgs by 1.5%, that theoretically should bump me up to 56!
Old 05-13-2011, 03:13 PM   #6 (permalink)
Easter McoModder
p.s. UFO, you have a beetle! I'm telling you, this is worth your time. It took me 10 minutes.
Old 05-13-2011, 10:26 PM   #7 (permalink)
Do more with less
OD - '05 Ford Econoline
90 day: 18.64 mpg (US)
90 day: 49.71 mpg (US)
90 day: 28.08 mpg (US)
At 49 mpg my jetta is burning 2.5oz of fuel a mile. Small things might make a difference. Be sure to drive without your AC and turn off your radio too.
Noah Webster, 1787
The Following User Says Thank You to Varn For This Useful Post:
SwamiSalami (05-18-2011)
Old 05-14-2011, 08:01 AM   #8 (permalink)
Ezcape - '15 Ford Escape Titanium
90 day: 20.22 mpg (US)
I'm surprized they still have them
"The Stone Age did not come to an end because we had a lack of stones, and the oil age will not come to an end because we have a lack of oil" ; His Excellency Sheikh Ahmed Zaki Yamani (Saudi Arabia Oil Minister from 1962 to 1986)
https://ecomodder.com/forum/em-fuel-...ehicleid=10608
Old 05-14-2011, 10:57 AM   #9 (permalink)
Easter McoModder
they're mandatory in a lot of places.
Old 05-14-2011, 06:04 PM   #10 (permalink)
The PRC.
I don't have DRLs on my (or Mrs A's TDIs) but we both run with headlights on (Xenons).
The result may be 1-2% MPG loss but to be honest a mistake on timing a light or timing a lane change or selecting when to shift up/down on a hill may make the same difference for or against FE on most journeys.
The positive result of lights on is that we have cut down the number of people pulling out without 'seeing' us by quite a bit. It is amazing how many do a double-take before deciding not to set off from a side road or change lanes.
So I'll stick with the lights.
daytime running lights, drl, new beetle drl, tdi drl
