Old 04-06-2011, 11:50 PM   #41 (permalink)
LegacyGT - '01 Subaru Legacy GT
90 day: 33.72 mpg (US)
Looking at their website, it looks like a number of companies signing on.
quite impressive
Old 04-07-2011, 12:13 AM   #42 (permalink)
I wonder why they don't simply put a taller cab air dam on, and increase the upper leading edge radius on the trailer?
Oh I see- this is a good marketing ploy to stand apart from the rest.
Old 04-08-2011, 03:29 AM   #43 (permalink)
FastPlastic's Avatar
98 Cherokee - '98 Jeep Cherokee
90 day: 17.18 mpg (US)
ZX7R Ninja - '99 Kawasaki ZX7R Ninja
90 day: 42.45 mpg (US)
So I know the topic has strayed a bit, but the thread reminded me about a photo I took a while back. After getting about 2" of snow, being the lazy man that I am, I cleaned the windows off and headed off to work. Top speed of about 35MPH for about 2 miles got me this on the roof. It's a bit hard to make out, but was fairly smooth up top.
Adjusted for my driving habits. 80%city/20%Highway.
20mpg city/30mpg highway or bust! Check out my mods so far
The Following User Says Thank You to FastPlastic For This Useful Post:
KamperBob (08-06-2012)
Old 04-19-2011, 04:53 PM   #44 (permalink)
XJguy's Avatar
My opinion would be to leave the roof as is,and go after the wake.I'm going to try and give you a link.It's a photo of a Rabbit with a similar roofline and completely attached flow,and then you'll see the enormous wake that's robbing you at the gas pump.-------------------------------------------------------- Fuel Economy, Hypermiling, EcoModding News and Forum - EcoModder.com - 's Albums
MODERATOR EDIT: Added by cfg83 :
Good comparo. The Jeep Cherokee's design was in part influenced by that car.
Old 04-19-2011, 05:01 PM   #45 (permalink)
XJguy's Avatar
Originally Posted by winkosmosis View Post
I wonder if they made the roof like that for aerodynamic reasons.
I do remember reading that more and more cars are getting arched roofs for aerodynamics, but I guess the question is whether you reduce total drag by adding an arch to an already flat roof and increasing frontal area
Many of these "aero" designs being implemented are just to give the consensus that they are more aerodynamic to the general public when in fact they are less so. Case in point, the Hybrid versions of the full size GM SUVs actually use sharper angled components than the regular models to promote sharp separation of flow. Another example the late model year F-bodies, although much more swoopy than the model they replaced are actually far less aerodynamic that the chiseled model of the late 80s.
Those rounded roofs may actually be causing more lift, hence more drag...but they look aerodynamic so the buyer thinks it is...and is more eager to get rid of his flat roofed SUV/wagon for a new one.
Old 04-19-2011, 05:06 PM   #46 (permalink)
XJguy's Avatar
You want to improve aerodynamics on an XJ, do as others have suggested, work on minimizing wake or promoting a clean break.
Prevent or minimize airflow into wheel wells, provide high pressure air evacuation.
Decrease the sharp transition from hood to wind sheild.
More aerodynamic side view mirrors.
More aerodynamic fender flares.
Provide through the hood air evacuation for radiators.
Smooth underbody if you keep current ride height OR lower body and install airdam as low to ground as possible to prevent air from going under Jeep.
Low drag wheels or wheel covers. Ford wheels are of the same bolt pattern and often same back spacing.
Old 04-23-2011, 12:11 AM   #47 (permalink)
I noticed a UPS truck today with an arched roof. I forgot to take a pic but it looked like this, except I think the arch was taller.
Old 08-05-2012, 03:35 PM   #48 (permalink)
Cd
Ultimate Fail
Cd's Avatar
Whatever became of this idea for the Jeep ?
Im curious to see it tested .
If it does anything but damage, you could even use it to store something in.
Old 08-06-2012, 09:27 AM   #49 (permalink)
Recreation Engineer
KamperBob's Avatar
Black Stallion - '02 Toyota Tundra 4WD xCab
Half Pint - '06 Yamaha XT225
Cool
I just stumbled on this thread over morning coffee. On page one I started thinking a snow carving might indicate bow splash from the windshield over the roof leading edge. A couple pages later I saw this. Excellent!
Recreation Engineer
Old 08-06-2012, 01:50 PM   #50 (permalink)
Sven7's Avatar
Boo Radley - '65 Ford F100
90 day: 13.28 mpg (US)
That is interesting. I guess the only way to know would be to tuft test, but that would require mounting a camera on a stalk to see the roof
I would still like to see some "before" tuft test results on this.
Roof rack test: quantifying the aero penalty MetroMPG Aerodynamics 30 02-10-2023 09:18 PM
Commercially produced aerodynamic pickup bed cap MetroMPG Aerodynamics 636 01-09-2022 07:21 PM
Minivan Kardboard Kammback boosts MPG +3.7% (6.6%, counting roof rack delete) MetroMPG Aerodynamics 31 05-20-2010 01:23 PM
weird rain flow patterns on roof lunarhighway Aerodynamics 5 07-08-2008 11:16 AM
Strange OEM Aerodynamic Shape (longitudinal roof indents) LostCause Aerodynamics 17 03-20-2008 12:26 AM
