Old 10-30-2010, 10:23 PM   #11 (permalink)
EcoSentra - '04 Nissan Sentra
90 day: 35.93 mpg (US)
Originally Posted by Arragonis View Post
I think unless someone specifically says Engine Off then assume they are on.
Up to now I have assumed that they are Engine Off unless they specifically say Engine On.
Old 10-30-2010, 11:43 PM   #12 (permalink)
Pishtaco
SentraSE-R's Avatar
Mean Green Toaster Machine - '06 Scion xB
90 day: 48.92 mpg (US)
It depends on the poster. I'm engine off at most opportunities - at lights & low speed P&G. But not during most high speed P&G.
Open loop is enriched operation, when the ECU isn't on its fuel map. Cold engines run open loop. When the engine warms up, modern engines go into closed (more efficient) loop. You need an Ultragauge or Scangauge to know which mode your engine is in.
Darrell
Boycotting Exxon since 1989, BP since 2010
Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac? George Carlin
49.5 mpg avg over 53,000 miles. 176% of '08 EPA
Best flat drive 94.5 mpg for 10.1 mi
Longest tank 1033 km (642 mi) on 10.56 gal = 60.8 mpg
Old 10-31-2010, 08:41 AM   #13 (permalink)
Coasting Down the Peak
skyl4rk's Avatar
Toyauto Pickup - '94 Toyota Pickup 2WD
90 day: 36.32 mpg (US)
Versa Base - '09 Versa Sedan 1.6 Base
90 day: 41.69 mpg (US)
Originally Posted by dcb View Post
and I think you just made up PNG
ahem
I think you mean "invented"
Nissan Versa Aeromods
Old 11-02-2010, 09:56 PM   #14 (permalink)
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
Originally Posted by skyl4rk View Post
ahem
Pressurized Natural Gas?
http://www.google.com/xhtml?q=png
Old 11-03-2010, 01:39 AM   #15 (permalink)
Smeghead
escort - '99 ford escort sport
90 day: 42.38 mpg (US)
scoobaru - '02 Subaru Forester s
90 day: 28.65 mpg (US)
nay, Pulse and Neutral Glide.
Learn from the mistakes of others, that way when you mess up you can do so in new and interesting ways.
One mile of road will take you one mile, one mile of runway can take you around the world.
Old 11-03-2010, 06:35 AM   #16 (permalink)
skyl4rk's Avatar
I always thought that P&G was pulse and glide with the engine on, and any time you turned the engine off it is EOC engine off coasting. I guess I have been wrong for a long time, I wonder how much misinformation I wrote over the past years. PNG is probably just a typo, maybe my mistake but I think I have seen it before in others writing.
Old 11-03-2010, 06:59 AM   #17 (permalink)
tumnasgt's Avatar
The Charger - '15 BMW i3
My thinking has been:
P&G - pulsing and gliding, engine can be on or off
EOnC - Engine on coasting, term generally used when coasting up to a red light or a reduced speed limit etc with engine on.
EOC - Engine off coasting, same EOnC with the engine off.
As I see it, P&G is a combination of techniques, whether you use EOC or EOnC as part of it doesn't really change the idea behind it, engine off just gives better results.
I've never assumed engine on or off, as many people aren't comfortable driving with the engine off (myself included) or can't because they have an automatic transmission.
Old 11-03-2010, 07:04 AM   #18 (permalink)
The PRC.
We can't even assume anything about the assumptions. My head hurts.
Old 11-03-2010, 04:51 PM   #19 (permalink)
The Mistress - '88 Bmw 320i Touring SE
Team m8
Last 3: 27.17 mpg (US)
Germany Beadle - '91 Mercedes 300td (estate, N/A)
90 day: 24.63 mpg (US)
The Bloodylingo - '05 Citroen Berlingo Multispace Desire
90 day: 39.77 mpg (US)
Shanner Scaab - '03 Saab 9-5 estate Vector
90 day: 26.19 mpg (US)
Clio 182 - '05 Renault Clio RS 182 182
90 day: 31.73 mpg (US)
i like your on off system.simple and easy to use.
p&g can be either on or off as long as the wheels are not being driven by the engine during the glide phase?
Old 01-06-2011, 12:26 AM   #20 (permalink)
the green machine :P - '97 Jeep Grand Cherokee ZJ
90 day: 20.92 mpg (US)
Thee s10 - '00 Chevy S10
90 day: 24.27 mpg (US)
Freedom - '05 Kawasaki Ninja 250EX
90 day: 75.55 mpg (US)
LE Focus - '05 Ford Focus
P&G - used between lights and stop signs when ur going to have to stop again(Engine off)
PNG - same as P&G but going into neutral(Engine on)
EOC - used for coasting down hills for extended periods of time or roads with enough slope(Engine off!!!)(Engine OFF coast)
Heated Fuel bennelson EcoModding Central 81 03-10-2022 11:28 PM
idea, 4 cylinder to 2 cylinder engine conversion saand EcoModding Central 152 01-02-2016 03:33 AM
Some Hypermiling techniques denounced by AAA Lazarus Hypermiling / EcoDriver's Ed 135 04-17-2011 04:07 AM
Mer-Chevy Project: Biofuel 40mpg Pickup bennelson EcoModding Central 128 07-27-2010 06:15 PM
Article: Lean burn on an otherwise stock engine (testing Acura RSX K-Series engine) tjts1 EcoModding Central 4 01-07-2010 01:22 PM
