Old 10-29-2010, 11:45 PM   #1 (permalink)
EcoSentra - '04 Nissan Sentra
90 day: 35.93 mpg (US)
Terminology for Engine off vs Engine on hypermiling techniques
Is there a good way to differentiate between Engine off and Engine on hypermiling techniques?
As I understand it EOC and P&G are typically engine off but don't need to be. I've seen some people use EO(n)C and EO(ff)C which is clearer but a little awkward. Haven't seen anything similar for P&G.
Just trying to get a better idea of what techniques people are using so I know what works and what works better.
Old 10-30-2010, 12:23 AM   #2 (permalink)
Pishtaco
SentraSE-R's Avatar
Mean Green Toaster Machine - '06 Scion xB
90 day: 48.92 mpg (US)
Talk to six hypermilers, and you may hear half a dozen different descriptions of what they do. One will glide, another will coast. A third will say he does it NICE-on, the fourth does EOC.
My '02 SE-R didn't like the engine off, so I rarely shut it off. If I did, it would run in open loop for 4 miles, negating all the gains I made from shutting it off. It also hated to go into DFCO. I had to be over 2500 rpm to get DFCO, 65 mph or faster in 6th gear. It was a difficult car to hypermile.
My '06 xB can coast engine off for miles, and still be in closed loop when I restart it. It loves DFCO, entering it when the engine is >1500 rpm, about 35 mph or faster in 5th gear. It's a breeze to hypermile it.
Darrell
Boycotting Exxon since 1989, BP since 2010
Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac? George Carlin
49.5 mpg avg over 53,000 miles. 176% of '08 EPA
Best flat drive 94.5 mpg for 10.1 mi
Longest tank 1033 km (642 mi) on 10.56 gal = 60.8 mpg
Old 10-30-2010, 08:45 AM   #3 (permalink)
Coasting Down the Peak
skyl4rk's Avatar
Toyauto Pickup - '94 Toyota Pickup 2WD
90 day: 36.32 mpg (US)
Versa Base - '09 Versa Sedan 1.6 Base
90 day: 41.69 mpg (US)
PNG means pulse and glide with engine on
EOC means engine off coasting, usually with a bump start at the end of a coast.
Nissan Versa Aeromods
Old 10-30-2010, 12:49 PM   #4 (permalink)
Smeghead
escort - '99 ford escort sport
90 day: 42.38 mpg (US)
scoobaru - '02 Subaru Forester s
90 day: 28.65 mpg (US)
my understandin/vote is for.
EOC engine off coast
neutral coast is engine on
P&G pulse and engine off glide.
PNG pulse and neutral glide (engine on).
Learn from the mistakes of others, that way when you mess up you can do so in new and interesting ways.
One mile of road will take you one mile, one mile of runway can take you around the world.
Old 10-30-2010, 03:06 PM   #5 (permalink)
The PRC.
Apologies I probably started this (O)n vs (O)ff terminology mainly because I wasn't clear on the terms used - I think the explanations above probably clear it up.
I wanted to be clear on what I meant in my posts because I was looking at the effects of shutting off an engine with a turbo suddenly vs an engine which does not have one.
Old 10-30-2010, 04:21 PM   #6 (permalink)
skyl4rk's Avatar
PNG == P&G
and both are with the engine on
amirite?
Old 10-30-2010, 04:28 PM   #7 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Yes, you did, and I plan to use that terminology until I come across (and hardwire it into my brain) something better. By "better" I mean not only distinguishing between engine on and off, but also written in such a way that new members will not get it confused. For example, only recently did I find out that P&G implies engine offing, and not general "accelerate&coast regardless of the state of the engine".
Old 10-30-2010, 04:29 PM   #8 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
Originally Posted by skyl4rk View Post
PNG == P&G
amirite?
no, p&g is engine off according to the glossary
http://ecomodder.com/forum/showthrea...e-ii-3505.html
and I think you just made up PNG
Old 10-30-2010, 04:35 PM   #9 (permalink)
The PRC.
I have created a monster, a monster....
I think unless someone specifically says Engine Off then assume they are on. Of course feel free to ask, everyone is nice here.
Old 10-30-2010, 09:05 PM   #10 (permalink)
RSX2fast4mpg - '02 Acura RSX Type S
90 day: 38.22 mpg (US)
bubbatrucker - '98 Chevrolet K1500
90 day: 18.1 mpg (US)
Ok, tangent time. What's open loop vs closed loop and how would I know the difference while driving?
Heated Fuel bennelson EcoModding Central 81 03-10-2022 11:28 PM
idea, 4 cylinder to 2 cylinder engine conversion saand EcoModding Central 152 01-02-2016 03:33 AM
Some Hypermiling techniques denounced by AAA Lazarus Hypermiling / EcoDriver's Ed 135 04-17-2011 04:07 AM
Mer-Chevy Project: Biofuel 40mpg Pickup bennelson EcoModding Central 128 07-27-2010 06:15 PM
Article: Lean burn on an otherwise stock engine (testing Acura RSX K-Series engine) tjts1 EcoModding Central 4 01-07-2010 01:22 PM
